neeeddd help some 1 helppp>>>>
Old Jan 24, 2005 | 07:40 PM
SlAmMeD 91 HaTcH's Avatar
Default neeeddd help some 1 helppp>>>>
Hey I own a 91civic hb stdd the d15b1 motor took a **** so a buddy of mine replaced it with a 95cx motor same thing basiclyy,The problem i need help with iss everything is swapped correctly and the 1 thing is weird iss that the cx motor wouldent run with my std dizzy im not sure if its supposed 2 im just wondering i mean the guyy had found a dx 1 laying a round and it started rigt upp now the only thing iss, IT has a Idle problem real rough like its missfireingg but it wont stall down it just doesnt seem smooth but iff i mash the accelator it will go away into higher rpm but when the rpms come back 2 idle level it sounds like a wrx again ahah i just would like 2 noe whats upp i think its running rich and thiz problem is not comeing up on a check engine no codess it will drive fine down the street just when its idleing it goes crazy again like it wants 2 stall BUMP BUMP>>>???HELP PLZZ
Old Jan 24, 2005 | 10:18 PM
slomofo's Avatar
GDD Member
You got the right firing order?
Old Jan 24, 2005 | 11:38 PM
notstock93's Avatar
Default Re: neeeddd help some 1 helppp>>>> (SlAmMeD 91 HaTcH)
I have no idea about d-series but it may be an OBD problem. 91's are OBD-0, right? 95's would be OBD-I and cause a ruckus. This is just a stab in the dark, though.
Old Jan 24, 2005 | 11:45 PM
eda6's Avatar
Default Re: neeeddd help some 1 helppp>>>> (notstock93)
My car decided to sound like a wrx tonight as well....
Things to check tomorrow
Old Jan 25, 2005 | 02:26 AM
BUmppp anyone everything is back 2 obdo i guess 1 wire o2 and all what made it not start with the stdd dizzy just some 1 help i wanan fixxx thizz anyoing...BUMP BUMPP
bonta-kun
13
Mar 14, 2011 08:02 AM
Kirk@SyndromeAuto
Jan 31, 2007 08:45 PM
whiteef-8
22
Sep 12, 2005 07:40 PM
Chillin94hatch
Jul 22, 2004 01:59 PM
