Ntirous????
Old Jan 24, 2005 | 10:02 AM
snowwaitin's Avatar
Default Ntirous????
Whats everyones opinion on nitrous for the DC5?
Old Jan 24, 2005 | 11:35 AM
EP3 Racer's Avatar
Default Re: Ntirous???? (snowwaitin)
you mean for the K20 Engine? cuz dc... ep... uses Kseries
as far as my opinion, k-series responds to spray fairly well and when i used it was was just a little rocket
Old Jan 24, 2005 | 11:42 AM
Kal's Avatar
Kal
not a lot of ppl nitrous on the k motors for some reason. it's always a good, cheap alternative to boost if you do it safely.
Old Jan 24, 2005 | 12:04 PM
krystar's Avatar
bunch of ppl are spraying safely. keep it 50shot or 75shot on the stock ecu if you're brave. make sure your RPM window and WOT switches are all working. some guy just blew his engine up cause his WOT switch malfunctioned and he was spraying while cruising on the highway.
if you get kpro and bigger injectors, you can run the dry kit and tune power w/ kpro
Old Jan 24, 2005 | 04:34 PM
411performance's Avatar
Default Re: (krystar)
I am spraying (50 shot) with intake, race header, exhaust, and fuel rail.....never had a problem or even check engine light. Boost and juice is my goal
Old Jan 27, 2005 | 06:19 AM
sockvtec's Avatar
direct port is the most reliable way to boost, yet i is more expensive....personally i wouldnt use nitrous until i had built the internals just for extra security
Greenery18
Jan 30, 2007 11:13 AM
Speed Infliction
Jul 13, 2006 11:07 AM
forced00si
Aug 15, 2004 06:39 PM
Teen Heartthrob
May 13, 2002 04:00 PM
Cru_Jones
Jul 21, 2001 04:31 PM
