d6y7 turbo question
i have a turbo in my car, i was wondering if oil come out of the turbo and into the
innercooler and into ur intake will it mess up my engine?
oil is not post to go in there rite ? just air ??????? help new at this thanz
theres supposed to be a very slight oil feel. its called blow-by. if theres a lot, thats bad. check your oil return line. i learned that the hard way b/c mine somehow got kinked. byt i put a new oil return and no more oil into the IC
what happen if there is alot what can i do i stop it i check my line it is fine no leaks
the promblem is that when i check my piping to do it agian there is alot of oil on it
i thought sir post to go in there onlie but i think i qaurt when in there so is bad
right ????? what you guys think the promblem is?
what happen if there is alot? what can i do to stop it ? i check my line it is fine no
leaks ,
the problem is that when i check my piping to do it agian there is alot of oil in it
i thought air post to go in there onlie, but i think 1 qaurt of oil went in there . so is
that bad ????? help plz thanx
leaks ,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmaballer »</TD></TR><TR><TD CLASS="quote">please use correct grammers and spelling it's so hard to read..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmaballer »</TD></TR><TR><TD CLASS="quote">please use correct grammar and spelling it's so hard to read..
you can tell he's asian by the way it reads. No offense.
</TD></TR></TABLE>you can tell he's asian by the way it reads. No offense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzNsTyLe361 »</TD></TR><TR><TD CLASS="quote">what happen if there is alot? what can i do to stop it ? i check my line it is fine no
leaks ,
that bad ????? help plz thanx</TD></TR></TABLE>
yes that is bad! there is nothing u can do except replace/rebuild the turbo. your current turbo seals are shot!
leaks ,
