can i run a vtec motor on a non vtec computer and wiring?
Old Jan 20, 2005 | 06:40 PM
DOHC_VTEC69's Avatar
Default can i run a vtec motor on a non vtec computer and wiring?
this might be a dumb question, but id like to save some money by not buying vtec setup,
Old Jan 20, 2005 | 06:41 PM
HATCHingMN's Avatar
Default Re: can i run a vtec motor on a non vtec computer and wiring? (DOHC_VTEC69)
yes, but you will have NO vtec
Old Jan 20, 2005 | 06:47 PM
eK9aT10pSi's Avatar
your q conflicts with what your asking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC_VTEC69 &raquo;</TD></TR><TR><TD CLASS="quote">Re: can i run a vtec motor on a non vtec computer and wiring?</TD></TR></TABLE>
yes you can, just no vtec, as said by hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC_VTEC69 &raquo;</TD></TR><TR><TD CLASS="quote">this might be a dumb question, but id like to save some money by not buying vtec setup,</TD></TR></TABLE>
if you by a vtec motor, you'll have vtec. but your going to need to correct ecu.
what is the point of the title and your statement?
Old Jan 20, 2005 | 06:51 PM
92orangeeg's Avatar
yes but novtec so just get yourself the ecu that came with the motor
HATCHingMN's Avatar
No vtec and not using correct ecu means you wont have any power at all!!
get the correct ecu and start enjoying the power of honda vtec
Old Jan 20, 2005 | 07:13 PM
hondadriver's Avatar
Default Re: can i run a vtec motor on a non vtec computer and wiring? (HATCHingMN)
Yes he can, for example if he is doing a mini me he can keep his stock ecu, and use a rpm activated switch. Like I did for 2 years on my mini me before I got the B16. But you can't use a stock D-series ecu on a B16 and expect to turn vtec on with a rpm activated switch.
Old Jan 20, 2005 | 08:14 PM
Benbuilt4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">yes, but you will have NO vtec </TD></TR></TABLE>
Old Jan 20, 2005 | 08:18 PM
Default Re: can i run a vtec motor on a non vtec computer and wiring? (hondadriver)
its not a b16 its sohc d16 and i got it for free to replace the blown sohc d16 non vtec, and i want to swap motors and not have to go get vtec ecu and wiring harness's etc...BECAUSE IM BROKE!!!!!!!!!!!!!!!!!!!!!!!!!1
Old Jan 20, 2005 | 08:24 PM
murmur9's Avatar
well...if you need an ECU for a vtec D16y8 hit me up.... i have one laying in my room. Ill let it go for 65$.....shipped to your front door.
The car will run...but it will run like ****....just buy the right ecu.
Mr.ITB
10
Mar 19, 2007 05:57 PM
CodyC142
13
Apr 13, 2006 09:34 AM
chinkest_raver
Aug 19, 2005 06:17 AM
97dc2
Sep 23, 2004 12:00 AM
escape2me
Apr 26, 2004 02:44 PM
