oil
Old Jan 20, 2005 | 09:42 AM
xthegoochx's Avatar
Default oil
i just bought a car running 11.5:1 compression ratio, and i changed the oil putting in 5w-30. the car is going through it like nobody's business but the engine was built less than 30k miles ago. my question is should i go to a heavier weight oil, or should i be worried about the piston rings? please let me know.
Old Jan 20, 2005 | 01:03 PM
Perfectionist's Avatar
Default Re: oil (xthegoochx)
A heavier weight oil will not significantly reduce oil consumption and could cause lubrication problems. You need to determine how the oil is being consumed. Is it smoking at idle, under heavy acceleration, or all the time? These symptoms are clues to what you need to do to correct the problem.
Old Jan 21, 2005 | 11:17 AM
xthegoochx's Avatar
Default Re: oil (Perfectionist)
no man, there is no blow by, no smoke any time, start up, idle, or even under heavy accelration, which is why i have no idea what the deal is.
Old Jan 21, 2005 | 11:31 AM
ralphie14's Avatar
Is there any oil on the block or engine bay that would signafy a leak anywhere?
Old Jan 21, 2005 | 11:39 AM
xthegoochx's Avatar
Default Re: oil (ralphie14)
not that i can see, but i do believe im running rich, a bunch of black stuff all over my bumper after a while of driving. this problem i hope will be fixed with tuning.
Old Jan 21, 2005 | 11:48 AM
ralphie14's Avatar
when you say that it is not smoking at all do you know this becuase someone was driving behind you in all those conditions and was watching or just because you could not see it in the rear view mirror? And how do you know that you are using so much oil? Do you check it all the time. Just a few questions.
Old Jan 21, 2005 | 11:58 AM
xthegoochx's Avatar
yeah bro,since ive been noticing that it has been buring it, i check almost every time i get in. and i dont notice any smoke, and ive had people drive behind me to make sure.
EG-SIXV-TEC
11
Dec 13, 2012 02:45 PM
De_tour
Aug 20, 2007 04:42 PM
RaVAGE00
Jul 1, 2003 05:40 PM
LB CRX
Oct 20, 2002 08:14 PM
