Too Much Oil
Old Jul 1, 2003 | 09:22 AM
RaVAGE00's Avatar
New User
Default Too Much Oil
what are some symptoms of too much oil in your engine? I have a type R and noticed that the oil was down.... So I added some oil.... fired her up.... the idle seems a little high - 1100 rpm....
Also, I dont leak oil, I dont burn oil at least no that I can tell.... but the oil must be going somewhere?
Old Jul 1, 2003 | 09:43 AM
RCautoworks's Avatar
Default Re: Too Much Oil (RaVAGE00)
Look at the dipstick and see if you are over the line.
Old Jul 1, 2003 | 09:49 AM
RaVAGE00's Avatar
New User
Default Re: Too Much Oil (90blackcrx)
i am not over the line.... i am in between the bottom and top hole....
Its very odd.....
Old Jul 1, 2003 | 09:54 AM
Then you don' have to much oil, when are you checking it ?
Old Jul 1, 2003 | 11:16 AM
Kamin's Avatar
its normal to idle high when you first turn the car on, or when the car is cold.
and its also normal to burn a little oil between changes, not much but a little.
Old Jul 1, 2003 | 05:40 PM
RaVAGE00's Avatar
New User
Default Re: Too Much Oil (Kamin)
the idle problem seems to gave disappeared just as fast as it appeared.... anyhow, I am going to the dealership to have them do a compression test..... I dont leak or burn oil.... but I have to top the oil up every 500 - 700 KM's.
I have enough freinds with R's to know that these cars do burn oil, especially synthetics... I use MOTUL 8100, however, since I have warranty still available... I might as well use it.
Inextricabledrvr
May 3, 2008 09:42 AM
Azxster
Jan 8, 2008 04:36 PM
SOHC_MShue
Jul 25, 2005 10:36 AM
mattcalica
Jun 12, 2004 01:47 AM
RaVAGE00
Jul 1, 2003 04:36 PM
