wiring purge cut-off solenoid
Old Jan 18, 2005 | 08:25 PM
rasta420's Avatar
Default wiring purge cut-off solenoid
i have a 90 crx si. im trying to wire up the purge cut-off solenoid on the d16z6 intake manifold on my d16z6 swap. im using the stock d16a6 wiring harness, so the connectors have to be swapped since they dont fit.
the stock harness uses green and black color wires. i have a connector that fits on the solenoid, but it has different colors on it so i dont know which wire to connect to which. someone have a pic or maybe you can try to describe which side the green wire goes to and which side the black wire goes to?
Old Jan 18, 2005 | 09:03 PM
Rywire's Avatar
Default Re: wiring purge cut-off solenoid (rasta420)
You can just use the crx one if you want, but if you have to use the z6 one thats fine too.
Tee black is 12V power, and the grn goes to the ecu. You can just extend the wire on the firewall, and connect the round plug.
OR, wire it up in the harness, add one wire to the 12vpower, and the other to ecu. Top or btm dosent matter on the round plug.
Old Jan 18, 2005 | 09:58 PM
trustnoone7935's Avatar
420 eastcoast where's it at, fire it up!!!!!!!!!!!!your VA friends lol
mithious
Jun 4, 2015 08:10 PM
ineedavtec
Jan 7, 2012 12:31 AM
89sib16
Mar 3, 2004 02:34 AM
AdamITR
May 14, 2003 05:44 PM
43MA
Feb 24, 2003 09:40 AM
