Broken key in ignition
Old Jan 18, 2005 | 03:49 PM
Spoolin93si's Avatar
Default Broken key in ignition
I let my friend borrow my car earlier and he ended up breaking half of the key off into the ignition. What is the best way to get it out?
Old Jan 18, 2005 | 03:57 PM
hawaiianbro's Avatar
Default Re: Broken key in ignition (Spoolin93si)
Maybe a strong magnet will work??? lol or you could have a locksmith come over and check it?
Old Jan 18, 2005 | 03:58 PM
Default Re: Broken key in ignition (hawaiianbro)
I had thought about the magnet too. I'm going to try that out first. Don't want to call the locksmith
Old Jan 18, 2005 | 04:00 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoolin93si &raquo;</TD></TR><TR><TD CLASS="quote">I let my friend borrow my car earlier and he ended up breaking half of the key off into the ignition. What is the best way to get it out?</TD></TR></TABLE>
take all the plastic off the steering column. so you see the ignition part... take a screw driver and turn the key to the "1" position.. and leave it there... and you will see a small circle on the top of the ignition area. and all you do is push that down and pull the key tumbler out. and then remove the broken key. and then put the tumbler back in..
and any key place can make a copy of your key even if its broken in half. or get a key at the dealerhip.
Old Jan 18, 2005 | 04:01 PM
MadRussian03's Avatar
is the broken peice not visible? you cant grab a hold of it? Hmm, hope what that ^^^^^dude said works.
Old Jan 18, 2005 | 04:06 PM
Default Re: Broken key in ignition (cxSHOE)
Thank you very much, great info. I'm going to try that first thing tomorrow when there is some light.
Old Jan 18, 2005 | 04:48 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoolin93si &raquo;</TD></TR><TR><TD CLASS="quote">Thank you very much, great info. I'm going to try that first thing tomorrow when there is some light.</TD></TR></TABLE>
Or you can call the locksmith to get it out and make your friend pay for it.
Old Jan 18, 2005 | 05:08 PM
numbnuts22715's Avatar
if you can get close to it grab a pair of needle nose pliers and try that way. seems easiest
Old Jan 18, 2005 | 07:36 PM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawaiianbro &raquo;</TD></TR><TR><TD CLASS="quote">Maybe a strong magnet will work??? </TD></TR></TABLE>
too bad keys are NOT magnetic.
just get a pair of fine tweezers and pull it out. infact taking out the tumbler is not that hard.
bfpicard
Mar 17, 2014 07:44 AM
SavMac14
Apr 2, 2013 09:35 AM
mickyT
Nov 10, 2007 08:46 PM
liljohnson
Aug 12, 2004 11:48 PM
wizzards581
12
Dec 11, 2003 06:25 PM
