turbo help
Old Jan 17, 2005 | 07:23 AM
Wookie768's Avatar
Default turbo help
i was gonna put this in forced induction but it gave me some message saying i cant
i have a completely stock civic 94 hatch
i have a chance to buy a used turbo with every thing except an intercooler from a friend
can my car take it?
its a d series engine
he also had it on his d series engine
will anyhting blow up in my car?
tranny engine we
what should i upgrade before hand?
Old Jan 17, 2005 | 08:00 AM
Jmunk's Avatar
Default Re: turbo help (Wookie768)
So many variables. Yes it will fit your car. Depends on what your HP goes are depends on what you upgrade. General rule is under 10 psi on stock internals with a good tune. Now psi and HP are two differnent things. I would say hit up http://www.homemadeturbo.com and read for the next week on this.
Old Jan 17, 2005 | 09:09 AM
TEAMTUNNELVISION's Avatar
The first thing I can say or would like to ask you is the kit for a D-series motor? What type of boost is this kit capable of making? From my personal experience 10 to 12 Lbs. of boost ( MAX ) is what I would put on stock internals. Before you install the turbo kit try finding out the possible HP the kit is cappable of making and order injectors accordingly also make sure you get atleast a 255 LPH fule pump. So you dont lean anything out then you`ll break something as apposed to blowing something up !
Old Jan 17, 2005 | 04:11 PM
Wookie768's Avatar
Default Re: turbo help (TEAMTUNNELVISION)
yea its a custom kit for a d series motor
Old Jan 17, 2005 | 05:01 PM
97VtecIN's Avatar
What size is the turbo? t3/t25/t66?? As long as you keep it under 10 lbs of boost then you should be ok keeping it stock, the only thing you would want to upgrade would be the injectors and fuel pump. A turbo timer increases the life of your turbo which is nice but not a requirement. BOV is highly reccommended. Also might want to consider hondata.
Old Jan 17, 2005 | 05:33 PM
Wookie768's Avatar
Default Re: turbo help (97VtecIN)
its a t3 turbo
Old Jan 17, 2005 | 05:43 PM
Wookie768's Avatar
ugh
he just told me the turbo needs to be rebuilt
so i think im not gonna do this anymore.......
unless its not difficult to rebuild on?
Old Jan 17, 2005 | 05:49 PM
97VtecIN's Avatar
Ok you have to weigh your options here, how much are you paying for all of this stuff?? If you are getting a good deal for the manifold and downpipe you still might want to consider it because it isn't hard at all to find a t3 for cheap, I'm not sure on the rebuild, that might be super easy.
Old Jan 17, 2005 | 05:52 PM
Wookie768's Avatar
350 bucks
all piping , t3 turbo , crx manifold, apexi bov
Old Jan 17, 2005 | 05:54 PM
huntarrr's Avatar
You'll blow it up if you don't know what you're doing.
Do some research on turbos (first learn how they work) and then buy your own kit depending on your goals. It might take a while, but you'll be more knowledgeable and probably won't blow up your motor.
Old Jan 17, 2005 | 06:04 PM
.Kevin.'s Avatar
my friend had a turbo on his car, well tuned, running 9psi and the engine lasted a year. his enigne was a d16y7.
ribal_gh
Jan 10, 2013 09:59 AM
rez624
Nov 4, 2010 12:05 PM
93daboy
Aug 24, 2009 03:59 AM
dont_tri
Jul 13, 2007 06:19 PM
EP3tune2RULE
23
Mar 25, 2005 07:03 PM
