Fuel pump ?s.....greddy blue box?s
Old Jan 10, 2002 | 10:07 PM
5thgen's Avatar
Default Fuel pump ?s.....greddy blue box?s
Does the blue box adjust fuel like a FMU would? If not, how does it dump more fuel into the motor? I'm currently looking at an intank walbro high pressure for boosting 8psi on a greddy kit (d16z6). Down the road I may go FMU when I decide I want to boost more so I'll consider an inline pump then. But as far as preference, it really doesn't matter...... I'll get the pump that works out better.
So, with 8psi on a greddy civic kit, would a walbro 255 high pressure be fine....or inline? BTW I have done a search on this and it helped a lot. I just couldn't find anything specific with the blue box. Thanks.
Old Jan 11, 2002 | 04:32 AM
downpipe's Avatar
Default Re: Fuel pump ?s.....greddy blue box?s (5thgen)
the blue box adds fuel by sensing boost using the factory map sensor and increasing the injector pulsewidth accordingly. it also sends a fake map signal to the stock ecu so you won't throw any codes. it works fairly well until you try to boost too much and melt a piston, like i did.
as far as the fuel pumps go, you only need a high pressure pump if you are planning to go the RRR/FMU type setup. if you are planning on larger injectors, the you only need a high-flow pump, and, of course, something to tune the injectors.
i would be wary of running high fuel pressures to meet fuel requirements, but it does the job.
Old Jan 11, 2002 | 05:11 AM
willyboyK20's Avatar
Default Re: Fuel pump ?s.....greddy blue box?s (downpipe)
what are the wiring differences with using the blue box on the 96+ civic ex's. I heard there are some but i cant' remember where i got the info from. Or is it just better to use a missing link with a FMU
Old Jan 11, 2002 | 07:22 AM
VTC_CiViC's Avatar
Default Re: Fuel pump ?s.....greddy blue box?s (willyboyD16)
I'd use the blue box before an FMU for 8psi and under..
Old Jan 11, 2002 | 08:35 AM
td04civic's Avatar
Check out http://www.turbocivic.net
He has the diagrams for wiring up the blue box for 96+ civics.
Old Jan 11, 2002 | 09:42 AM
therealciviczc's Avatar
Default Re: Fuel pump ?s.....greddy blue box?s (td04civic)
Let me know if you need the blue box. I have a brand new unused one working as a paper weight right now.
Old Jan 14, 2002 | 12:07 PM
snt78's Avatar
Default Re: Fuel pump ?s.....greddy blue box?s (therealciviczc)
I need a blue box, how much do you want?
Old Jan 14, 2002 | 03:48 PM
boosted3g's Avatar
Default Re: Fuel pump ?s.....greddy blue box?s (snt78)
If your in the market for a high pressure walbro i have one that is barly used for sale. It is the one from Holley for forced induction. Ill let it go for 75 bucks shipped.
Boosted3g@aol.com
boostincoupe
Mar 5, 2004 08:04 AM
boostincoupe
May 9, 2003 10:33 PM
E-spec Tuner
May 7, 2003 02:05 AM
clean
Apr 15, 2002 04:45 AM
SiBirdie
Sep 28, 2001 09:31 PM
