f-max - does the wastegate need a boost source or vaccum/boost source
bov... boost/vacuum from intake manifold.
wastegate... boost only from turbo compressor.
avc-r... that's a little too complicated to explain here. read your instructions. if you don't have them u can download them from the internet.
it can go a number of different ways..
-BOV must be hooked up to vacuum/boost post throttle plate
-WG can actually be hooked up pretty much anywhere...on the compressor, on the charge pipe, or even to the manifold that has vacuum/boost.
i plan on hooking mine up to the charge pipe right before the throttle plate, as the directions for the tial say.
FOrSfEd
May 17, 2004 10:13 PM
