Vafc @ +23...
Old Jan 10, 2002 | 12:39 PM
MPH's Avatar
MPH
New User
Default Vafc @ +23...
Is it really that bad to plus it that high? Between 6000 and 6500 rpm I'm running lean (15.2) and I kept adding until I got down to 13.8. I was told that it's bad by some and was told it was fine by another.
Old Jan 10, 2002 | 12:48 PM
Black R's Avatar
25 Year Member
Default Re: Vafc @ +23... (MPH)
.....anything above 12%-15% on vafc isn't doing anything. Add fuel pressure instead and fine tune with vafc. Any detonation?
Old Jan 10, 2002 | 12:52 PM
VaporTrail's Avatar
New User
Default Re: Vafc @ +23... (Black R)
In my experience, I haven't been able to add more than 8% without tripping out the MAP sensor and throwing a code. Am I the only one who's had this problem?
Old Jan 10, 2002 | 12:55 PM
MPH's Avatar
MPH
New User
I thought the same thing, but I started by adding 3% and just kept going up because it was making a difference. No detonation. No cels.
Old Jan 10, 2002 | 01:01 PM
Black R's Avatar
25 Year Member
Yeah, but it won't be consistent. Do a few pulls and that problem of leaning out will be intermitent. Still there. For peace of mind, raise fuel pressure.....
Old Jan 10, 2002 | 01:09 PM
sgT's Avatar
sgT
Default Re: Vafc @ +23... (VaporTrail)
It depends on how close to 0 vacuum you are when you are doing this.
remember its not fuel, its map signal.
Old Jan 10, 2002 | 01:12 PM
VaporTrail's Avatar
New User
Default Re: Vafc @ +23... (sgT)
well, considering it's a built b20vtec we had this problem with, that would explain it. It modifies the MAP sensor values the ECU see's so that it fools the ecu into adding more fuel. Thanks for the info, I didn't think of that.
Old Jan 10, 2002 | 01:50 PM
Austin's Avatar
Have you tried increasing your Fuel Pressure, and then taking out fuel in the areas that your rich with the VAFC.
Austin
Old Jan 10, 2002 | 04:20 PM
Mike K's Avatar
Default Re: Vafc @ +23... (Austin)
I'd say it's time for some 270cc injectors.. maybe even 310s.
Old Jan 10, 2002 | 07:31 PM
VaporTrail's Avatar
New User
well, we are out of options on that. Fuel pressure is maxed at 56psi. Anymore than that and we kill fuel pumps. We're still running stock injectors. The entire air/fuel is still upwards of 13.5:1, as lean as 15:1 in the midrange. Our solution? Hondata stage 2 and 440cc injectors next week
typesguy
Sep 30, 2005 12:27 PM
B18CRacer
Apr 29, 2004 11:40 AM
spooned out
Aug 25, 2003 06:31 PM
GettaluvR
Apr 22, 2003 11:02 AM
Quick_lude
May 18, 2002 11:53 PM
