Vafc problem
Old Apr 21, 2003 | 11:35 AM
GettaluvR's Avatar
New User
Default Vafc problem
i had my turbo kit one day as some of you guys know, i took off right after,...$#@$# (doont ask why)
now i have everything back, all stock parts except my VAFC, but now i have a problem, my rpm is not smooth at 7k rpm, i stuck there for few sec and my enigne sound like it's going to blow, i didnt set anything on the VAFC. is it coz the default setting on VAFC cost this or OBD2 dont work with VAFC ?
my car is so slow now, what should i do. should i just take out the vafc or have it tune ?
thanks
Old Apr 21, 2003 | 01:19 PM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Vafc problem (GettaluvR)
Have it tuned on a dyno with a wideband. Tuning blind with a VAFC is a good way to make piston soup.
In the meantime I would bump your fuel pressure by a few psi just to be safe.
Old Apr 21, 2003 | 01:28 PM
GettaluvR's Avatar
New User
Default Re: Vafc problem (newt2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newt2 &raquo;</TD></TR><TR><TD CLASS="quote">Have it tuned on a dyno with a wideband. Tuning blind with a VAFC is a good way to make piston soup.
In the meantime I would bump your fuel pressure by a few psi just to be safe. </TD></TR></TABLE>
but i dont have the turbo kit no more tho, evrything is back to stock, do i still need to adjust fuel ? if so does this mean that VAFC's default setting is different than stock ?
or should i just take it out, if i do would everything setting back to stock ?
Old Apr 21, 2003 | 01:41 PM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
If you're going to stay stock, just take it out.
Old Apr 21, 2003 | 04:18 PM
GettaluvR's Avatar
New User
what if i'm going to have header cai exhuast, maybe even toda cam shaft ? should i leave it ?
do u have to tune it after you install the VAFC ? is it normal my car dont get enough fuel because install the vafc ? i didnt change any setting tho ?
Old Apr 21, 2003 | 07:22 PM
GettaluvR's Avatar
New User
anyone ?
Old Apr 21, 2003 | 08:04 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Uh your statements are a little hard to read to say the least. First off check the basic stuff. See if your car is throwing a code, check the spark plugs, things like that. If you don't find anything try unhooking the VAFC and rewiring the ECU back to see if the car runs correctly. You did remember to reset the VAFC after you went back to stock? If you re-initialize the the VAFC and you are basically stock the car should run find unless you have a bad wiring connection.
Old Apr 21, 2003 | 09:29 PM
VTHokie's Avatar
Default Re: Vafc problem (ActiveAero)
If you initialize the set up, i believe it will go to the original vafc setup. This can mean its not set up correctly, i forgot the initialized settings, but im almost positive that you have to change the sensors or the # cylinder car you have. Go though the basic setup procedures in the manual to set it back to stock. But if you are really going back to stock, i would just take it out.
Old Apr 22, 2003 | 06:02 AM
PM-Performance's Avatar
Default Re: Vafc problem (VTHokie)
yea make sure its intialized and set everything to zero
whyd you take the turbo out ?
Old Apr 22, 2003 | 06:32 AM
GettaluvR's Avatar
New User
Default Re: Vafc problem (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">yea make sure its intialized and set everything to zero
whyd you take the turbo out ?</TD></TR></TABLE>
k thanks i'll try that !
and why no turbo ? hehe couldnt pay for it ! cost me around 2.5k to get parts and tune....$#@$@ and got school fee to pay so...
Old Apr 22, 2003 | 06:45 AM
so you put it in already and thne took it out ?cuz you couldnt afford tuning ?
aye aye aye , please tell me im missunderstanding
Old Apr 22, 2003 | 07:22 AM
uNF$@#!'s Avatar
reinitialize the vafc. stock ecu settings will take place.
[playing dumb] btw, so why did you take off your bolton turbo kit again?[/playing dumb]
Old Apr 22, 2003 | 11:00 AM
GettaluvR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">so you put it in already and thne took it out ?cuz you couldnt afford tuning ?
aye aye aye , please tell me im missunderstanding </TD></TR></TABLE>
nope u got it rite
i didnt want it in there untuned and damage my engine so i took it out
Old Apr 22, 2003 | 11:02 AM
GettaluvR's Avatar
New User
Default Re: Vafc problem (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">reinitialize the vafc. stock ecu settings will take place.
i did reinitialize and only set sensor in 06 out 06 and cylinder to 4, and it's still doing it ! btw when my vtec kicks in my VAFC didnt say it ! it says still off. and my rpm on vafc is not moving only throttle is moving whenever i rev.
does this sound like wrong wiring ?
Quick_lude
May 18, 2002 11:53 PM
MPH
Jan 10, 2002 07:31 PM
ITR 01-0840
Jan 7, 2002 04:59 PM
