URGENT****Need help real fast!
I'm trying to pull the motor out of my EG and i hit a brick wall just a while ago. The wheel lock is on the left side wheel and i dont have the key for it. I called a bunch of places and asked if they sell universal lock removers or if they sold keys but they dont. There were two options. 1. get a guy to come over to my house and do it for 70 bucks or 2. use a tow dolly to get the car to the shop and have them remove it.
The car doesn't move cuz I already drained and disconnected everything. Plus it spun a rod. Anyway I was wondering if anyone knew of a way to get past this. Is there any way I can get the axle out without taking the tire off of the left side?
i used one of these kits before and it worked awesome. not cheap though.
http://store.autotoolexpress.com/ame400.html
i'd be willing to bet that this may work too, if you can get it over the wheel lock.
http://www.sears.com/sr/javasr...66000
if you can get to the side of the lock with a punch and hit it with a mini sledge hammer you might be able to get it, it would take a few minutes to break it loose but it can be done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherroneballs »</TD></TR><TR><TD CLASS="quote">if you can get to the side of the lock with a punch and hit it with a mini sledge hammer you might be able to get it, it would take a few minutes to break it loose but it can be done.</TD></TR></TABLE>
Hmm.. I didn't quite understand. Are you suggesting that I hammer the wheel lock and try to break it to pieces?
LOL I'm not being sarcastic, if it can be done that way then i'll try it.
Is there a way of hammering a socket over the lock? If you don't mind replacing a stud, you can just drill out the stud and break the wheel lock off and then replace the stud.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherroneballs »</TD></TR><TR><TD CLASS="quote">no just take a some what pointed punch, put a indent in the lock and hit it towards the left to loosen.
It's hard to explain</TD></TR></TABLE>
Have you done this yourself on a wheel lock? It seems kinda hard to break loose a wheel lock with a punch when something is torqued to 80ft lbs. Especially if its a place where you don't have much room or leverage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris c »</TD></TR><TR><TD CLASS="quote">i used one of these kits before and it worked awesome. not cheap though.
i was just thinking the same thing with those craftsman stripped bolt removers, and how they would probably work. I would definently try that.
Hmm thanks for the help guys. I'm going to see if I can't just get the thing over to the nearest tire shop and have them remove it for 25 bux. Thankfully a friend is letting me borrow his dolly for a while so that's half the problem.
if you had access to a welder just weld a regular lock onto the lock lug and loosen it that way. i know it's hard to get a hold of a welder. unless you have one like me
Something really cheap an that I've heard of. Get metal bonding glue from Home Depot or something and put a ratchet head that fits (somewhat) on there and just torque it off.
