What else needed with hondata.
Old Jan 12, 2005 | 10:27 PM
chihuahuamanx's Avatar
Default What else needed with hondata.
Im going to be running my hondata system on my prelude with my turbo set at about 6 pounds of boost. to get it tuned what else will I need?
My injectors are pretty big for honda injectors and i was wondering if i could keep them for now and later upgrade to some DSM injectors.
What about a fuel pump? Do i need a larger one? thanks, peace.
Old Jan 13, 2005 | 01:09 AM
TeStUdO's Avatar
Default Re: What else needed with hondata. (chihuahuamanx)
I would replace your injectors for some 440's or some DSM 450's. Also buy a 255lph in tank fuel pump
Old Jan 13, 2005 | 02:03 AM
SlowReaction's Avatar
Default Re: What else needed with hondata. (TeStUdO)
You will definetly want to upgrade your injectors. 440cc would be the smallest you'd want to run. Personally I'd go with something big incase you want to run more boost in the future. Full Pump is a must also. 255 as stated before. Also find a good tuner who knows what their doing and has some knowledge of the system. The last thing you'll want is a blown motor.
Old Jan 13, 2005 | 07:24 AM
Default Re: What else needed with hondata. (SlowReaction)
is my $1000 hondata budget unrealistic then? If i get the system for $500, i could get injectors and a pump for say.... 200? leave me with a good 300 for tuning?
Old Jan 13, 2005 | 10:20 AM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chihuahuamanx &raquo;</TD></TR><TR><TD CLASS="quote">is my $1000 hondata budget unrealistic then? If i get the system for $500, i could get injectors and a pump for say.... 200? leave me with a good 300 for tuning?</TD></TR></TABLE>
1000 seems like a good budget to me. It also depends what options you want with the Hondata-------------i.e. @ or 3 step boost control, datalogging and so on.
Old Jan 13, 2005 | 04:05 PM
aight, coo coo. Im going for a basic boost system now, and Ill upgrade later when I can afford it and probably work on tuning myself. Any other recommendations?
Old Jan 13, 2005 | 07:18 PM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
definently get bigger injectors. if not, you'll come to find out you could be running 90-100% duty cycle on you injectors. i.e. no good
Old Jan 13, 2005 | 09:18 PM
Default Re: What else needed with hondata. (h22boy)
and I take it I cant run bigger injectors w/o a new fuel pump?
Old Jan 13, 2005 | 09:37 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chihuahuamanx &raquo;</TD></TR><TR><TD CLASS="quote">and I take it I cant run bigger injectors w/o a new fuel pump?</TD></TR></TABLE>
you can run it without a fuel pump
Old Jan 13, 2005 | 11:02 PM
Default Re: What else needed with hondata. (PrettyLude)
really?
kickass!!!
turbo h22's pwn everything. except like sushi. that **** pwns even h22's
RedZone
Oct 2, 2004 08:59 PM
frostcivic
Aug 6, 2004 02:22 PM
kuya kanin
Oct 2, 2002 06:28 PM
SickRevHrdTeg
Aug 19, 2002 01:19 PM
WykidEH
Oct 12, 2001 03:38 AM
