hondata
Old Aug 18, 2002 | 09:26 PM
SickRevHrdTeg's Avatar
Default hondata
Is it a good or bad idea to run hondata with the stock injecters and inline pump with intank pump all take the fmu and check valves out ofcourse? i dont have injectors yet should i wait and put in the hondata? Or is hondata stock injectors better than fmu and stock injectors?
Old Aug 18, 2002 | 10:14 PM
sushibug's Avatar
Default Re: hondata (SickRevHrdTeg)
you need to give more detail on your setup. hondas generally come stock with 240cc injectors. i believe this is good for roughly 200whp or so. if you make more power then that, you need bigger injectors.
Old Aug 19, 2002 | 07:33 AM
Default Re: hondata (sushibug)
That wasnt the question, the question was is it a good idea perfermance and safety wise to put in the hondata with just the kit and inline pump no injectors cause im on a budget right now?
Old Aug 19, 2002 | 07:50 AM
CovertFI's Avatar
stand alone fuel management is always better. if tuned right, of corse.
Old Aug 19, 2002 | 10:48 AM
C-speed's Avatar
If you are boosted, then NO.. if you are NA and less than 200whp, then the stock injectors are fine.
Old Aug 19, 2002 | 01:19 PM
Cramerox's Avatar
why dont u just wait? or get some dsm injectors for like 40 bucks.
chihuahuamanx
Jan 13, 2005 11:02 PM
frostcivic
Aug 6, 2004 02:22 PM
Diego Boost
Feb 26, 2003 11:10 AM
ALLMOTOR18
Jan 30, 2003 04:25 PM
civcexcoupeblack
Dec 16, 2002 01:16 PM
