Next best thing to air filter?
Old Jan 12, 2005 | 07:13 AM
scartail's Avatar
Default Next best thing to air filter?
I have no room to put any type of filter in. What can I do? Right now I have a wire screen. Is there something better?
Any suggestions would be great.
Edit: Found something! https://honda-tech.com/zerothread?id=1026693
Old Jan 12, 2005 | 07:49 AM
mrDFWmechanic's Avatar
are you talking about to put on your turbo ?? if thats what you mean you can do a wire screen or pantyhose just be sure to clamp it down so it doesn't get sucked in. or me creative and try somethin else.
Old Jan 12, 2005 | 07:53 AM
ILLICON3000's Avatar
Default Re: (iROCKtheSOHC)
I used an old polo sock. It was terrible for air flow but it worked at the time.
Old Jan 12, 2005 | 08:00 AM
RyanEJ8's Avatar
Default Re: (ILLICON3000)
IMHO, it's a bad idea to use anything but an air filter on your turbo. A screen or pantyhose might prevent any large rocks or debris from being sucked in, but you're still sucking in a ton of dust and small dirt molecules. You have any pics of your setup, I find it hard to believe that you can't find room for a filter with all the different sizes K&N makes.
Old Jan 12, 2005 | 09:47 AM
DaX's Avatar
DaX
Loved
Community Favorite
I currently run a screen, but I do realize it is terribly restrictive. It's all about surface area.
Old Jan 12, 2005 | 11:39 AM
Trac226's Avatar
Default Re: (DaX)
I had a pretty tight squeeze for my intake and filter, but with a couple pipe bends, silicon 90 degree transitions, and a lil vaseline =P, everything fits! Check out atpturbo.com for the silicon couplers.
Have you looked into the mushroom style filters like hks?
Old Jan 12, 2005 | 11:52 AM
yellowturbo's Avatar
KN or nothing... I cant belive how much dirt it catch when I clean it... sand, dirt etc.
All those thing can scratch your sleeve and damage your engine on a long period.
I just washed my KN last week with the special soap for it... it was full of dirt. I WOULD NEVER RUN A SCREEN.
Old Jan 13, 2005 | 06:33 AM
scartail's Avatar
Default Re: (yellowturbo)
i'll get some pix this weekend... it's really tight!! I had to cut some of the compressor stroud to make it fit!! currently i have a wire mesh on it...
DubyaAye
Oct 28, 2007 11:00 PM
92HB_HB
Mar 15, 2007 08:31 AM
dannydos
Jun 26, 2005 06:50 AM
blue_hatch
Mar 17, 2005 11:08 PM
ZCHF
Apr 22, 2003 08:46 AM
