Fuel and Spark...BUT does NOT start!!!
Old Jan 10, 2005 | 11:46 PM
Supahr_Ed's Avatar
Default Fuel and Spark...BUT does NOT start!!!
Hello, i need some help with a friends car.
Its a 95 integra LS auto, it has Fuel and has some spark. The spark looks small but maybe only compared to my car. The car is stock. All fuses are good. BRAND NEW DIST. so i dont think its the coil or ignitor not being able to spark enough.
It originally died, while moving. So i dont think its the main relay (?) since it was running before it choked and died. Timing looks good also...ANY HELP?!?!?
Old Jan 11, 2005 | 04:07 AM
JimBlake's Avatar
Default Re: Fuel and Spark...BUT does NOT start!!! (Supah_Eg6)
You say it has fuel... Do you mean the fuel pump is running, did you measure fuel pressure? Maybe there's fuel in the rail but the injectors aren't firing??
Old Jan 11, 2005 | 11:40 AM
primeredbeast's Avatar
check the plug wire order it's the simple things that can kill ya
Old Jan 11, 2005 | 03:57 PM
jason190's Avatar
You said it was a new Distributor? Take it out and and spin the fork on the DIS and put it back in. It's prolly 180 degrees off. It hapened to me and I was pissed for like 2 hours and then I just back tracked all my steps and fixed it.
Old Jan 11, 2005 | 05:19 PM
Supahr_Ed's Avatar
yea, check the distr. was the first thing i did. I thought it was 180 degrees off too. Wires are good....LS firing order is the same as GSR right?
The fuel pump is working but i dont know if there is fuel pressure. im pretty sure there is because the spark plugs are soaked after all the cranking..so fuel is going in the cynlinders..
thanks for all the help
Old Jan 12, 2005 | 04:01 AM
JimBlake's Avatar
Default Re: (Supah_Eg6)
The distributor has a blade that's off-center. It's possible to force it in backwards, but it's not real easy. (Unless your favorite tool is a BFH...)
Did you get the new distributor AFTER it died? Maybe the original problem was a bad coil or ignitor. Now with a new distributor/ignitor/coil, it doesn't start because the plugs are fouled from before?? I once had plugs that still didn't fire after I fixed the original problem & dried the plugs out. With NEW plugs it started right up.
Since the plugs get wet, you must have pressure & the injectors must be firing. That means the CKP, CYP, & TDC sensors down in the distributor must be OK.
If the FPR has ruptured, your fuel pressure might be way too high. Pull off the vacuum hose from the FPR - shouldn't be any gasoline in that.
Old Jan 12, 2005 | 07:04 AM
DIFFUT'S INC.'s Avatar
Default Re: (JimBlake)
CHECK YOUR TIMMING
Old Jan 12, 2005 | 08:48 AM
Lsos's Avatar
I'll tell you what I did when I was in the same situation as you...I got pissed. I showed the engine to like 10 different people including professional mechanics and no one could tell me what was wrong (in fact the mechanic was the most wrong). I just pulled the engine yesterday and I'll put a new one in.
Good luck man.
https://honda-tech.com/zerothread?id=1052043
Old Jan 12, 2005 | 08:18 PM
Supahr_Ed's Avatar
lol, damn the stories are stressful...but my friend actually bought a new dist. and then i told him to return it for another, I dont think the store will sell two bad distr. to us, there is a little spark.
Timing is good too...TDC with the white dot on the crank right? Doesnt look like its off a tooth or anything but belt looks old...
Old Jan 13, 2005 | 02:13 AM
SlowReaction's Avatar
Is the motor really old? Do a compression/leakdown and see what happens.
Old Jan 13, 2005 | 05:59 AM
ricodemus's Avatar
Default Re: (SlowReaction)
I was just in a similar situation, I'll just tell the story. Car died while running. Cranked fine, no start. I tried to crank it a bunch of times, all with the same result. I could hear the fuel pump priming, so I didnt think it was that along with fuel on the spark plugs. There was no spark, so we replaced the ignition coil in the distributor. Now we have spark, but it's still not starting. Hmmm, timing belt snapped too (what are the odds?). Put on a new one and it's still not starting. Come to find out it was 1 tooth off (the cam gears "up" had to be tilted a little towards the front) causing it wouldnt start. Also, the engine must have flooded from all the cranking so we took out the spark plugs, unplugged the injectors and cranked and let some of the gas shoot out. She eventually fired up and ran pretty good, I got lucky no valves or pistons destroyed each other.
Old Jan 13, 2005 | 06:38 AM
Default Re: (ricodemus)
???????? thinking mMmmmmMm
Old Jan 13, 2005 | 06:40 AM
pwr2lbs's Avatar
If the timming, fuel and spark are fine i would do a compresion test.
Old Jan 18, 2005 | 06:11 PM
Supahr_Ed's Avatar
i will try a compression check, i bet its bad cause it does have about 160K but i doubt this cause the motor to died out while it was moving... thx people...any more experiences?
Old Jan 18, 2005 | 06:24 PM
jason190's Avatar
The same thing happened to me this week. apparently I was asking to much for the stock coil and blew 2 stock coils. So I went back to the MSD.
91da_teg
Jan 21, 2009 11:16 PM
boosted423
Aug 4, 2008 08:20 PM
ForceFedEg
Mar 4, 2007 10:42 AM
patrick4588
May 26, 2006 03:14 PM
Eg4-TuRbO
Jul 30, 2004 11:48 PM
