car wont start
Old Jan 20, 2009 | 08:58 PM
91da_teg's Avatar
From: boiling springs, south carolina, united states
Default car wont start
i bought a 91 acura integra shell and bought the stock ls to put back in, went to try to start the car and it turns over just wont start,its geting fuel and geting spark,need help pleas
Old Jan 21, 2009 | 05:03 AM
fcm's Avatar
fcm
Old Fart
Default Re: car wont start
If it is getting fuel and spark, and your sure about that, then check timing. 94
Old Jan 21, 2009 | 01:58 PM
91da_teg's Avatar
i checked the timing 2 its good,thanks man what else could it be
Old Jan 21, 2009 | 04:02 PM
fcm's Avatar
fcm
Old Fart
It has to be one of them, are you sure you have good fuel pressure and a good spark.
Is firing order correct???
How are you testing for fuel and spark? 94
Old Jan 21, 2009 | 07:27 PM
91da_teg's Avatar
i pretty shure its not fuel because ate first i dident have the fuel rail on good and it was spraying fuel and i have a walbro 255 fuel pump and i have already put a new distributor on it off a friends, there is something weird i can smell the fuel rilly strong out side the car
Old Jan 21, 2009 | 09:43 PM
untitledsn41's Avatar
clogged injectors? did you clean the fuel rail before you put it on? check firing order as well, perhaps you put the #1 plug on in the wrong spot on the distributor.
Old Jan 21, 2009 | 11:16 PM
91da_teg's Avatar
the injecters are pushing gas but i havent checked all of them,yea the firing order is right,thanks man ill check thr injectors
jakemuny
Apr 12, 2010 03:41 PM
accord-h22
Feb 13, 2007 04:45 PM
EGNA
Jul 12, 2006 03:31 PM
Supahr_Ed
Jan 18, 2005 06:24 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
