NO VTEC
Old Jan 9, 2005 | 06:35 PM
ferio 95's Avatar
Default NO VTEC
Ok im basically fed up with ******* with vtec on my gsr. ive rewired all vtec related switches and sensors and it still wont engage. code 21 vtec solenoid is in but i tested the solenoid and it clicks just fine but still wont engage. wtf is going on here?
Old Jan 9, 2005 | 11:02 PM
ferio 95's Avatar
Default Re: NO VTEC (ferio 95)
help?
Old Jan 10, 2005 | 08:01 AM
CruznDubz's Avatar
u may want to do an oil change to it and you may also want to check your oil pressure if you have not already done so....
Old Jan 10, 2005 | 08:50 AM
T4eg's Avatar
Default Re: NO VTEC (CruznDubz)
has the head been apart? the shaft that the rockers are on has pins in it. If the pins arnt there u wont have vtec. Just a idea
Chris
Old Jan 10, 2005 | 05:59 PM
hOndafienD 04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CruznDubz &raquo;</TD></TR><TR><TD CLASS="quote">u may want to do an oil change to it and you may also want to check your oil pressure if you have not already done so....</TD></TR></TABLE>
Old Jan 10, 2005 | 07:27 PM
ferio 95's Avatar
Default Re: NO VTEC (hOndafienD 04)
well oil is fine. the problem now is that my vtec solenoid keeps showing a cel. BUT i tested it and it still clicks so i hardwired it strait to the ecu and it still throws a code
Old Jan 10, 2005 | 08:03 PM
ecu itself come have something wrong with it....it could happen.
Old Jan 10, 2005 | 08:47 PM
ferio 95's Avatar
Default Re: (hOndafienD 04)
i have my stock gsr ecu as well as a chipped p28. on the p28 it dont show up as a cel but still no vtec
Old Jan 10, 2005 | 09:00 PM
stickyfingers's Avatar
PM sent does you speedo work???
Old Jan 10, 2005 | 09:52 PM
ferio 95's Avatar
Default Re: NO VTEC (stickyfingers)
like a charm
Old Jan 11, 2005 | 03:34 PM
ferio 95's Avatar
helllllllp
Old Jan 11, 2005 | 05:43 PM
cstay's Avatar
drive down the road with a voltage meeter on the vtec seloniod and se if the selinoid is getting voltage if not then its eather another sensor or your ecu or wiring if it is getting power its most likely selonoid i dont think u would get a cel if your rockers werent put in right the computer wouldidnt be able to tell.
Old Jan 11, 2005 | 06:09 PM
ferio 95's Avatar
Default Re: NO VTEC (cstay)
ok my vtec solenoid is perfect this i no for a fact. ive tested it numerous times. the problem im having is that the ecu signal isnt reaching the solenoid to activate it. i have the solenoid wire extended all the way to the jumper harness so its bypass all plugs and should be working like a charm but it isnt
Old Jan 11, 2005 | 10:49 PM
ferio 95's Avatar
all right folks figured out that i had my positive wire from my vtec solenoid crossed with the postive from my oil psi switch. thanks to help from BuleHatch00 everything hauls just fine
Old Jan 14, 2005 | 11:29 AM
evilsolb16's Avatar
you may have a bad ground on the solenoid. if ground is good go and double check make sure you wired it in the right ecu pin.
Old Jan 14, 2005 | 02:19 PM
ferio 95's Avatar
Default Re: NO VTEC (evilsolb16)
not trying to sound like an *** but check my previous post, i fixed it already. besides the vtec solenoid doesnt have a ground wire since it grounds it self
tigasin
Nov 14, 2008 11:58 PM
karkrazy9
Jun 29, 2008 07:35 PM
JSpekBB4
Oct 30, 2007 10:23 PM
egmatt93
Dec 5, 2006 08:29 PM
spoonef
Feb 28, 2003 10:01 AM
