JUST did compression test....Can I boost on these number, or should I rebuild ?
Old Jan 9, 2005 | 01:12 PM
MikeTV
Guest
Posts: n/a
Default JUST did compression test....Can I boost on these number, or should I rebuild ?
Hey guys..just did a compression test today on my 95 gs-r with 190,000 miles on it.
Results were: 195-195-195-190
How are these numbers, and can I throw boost on this engine or should I rebuild ?
Before people start hijacking this thread, let me just say this really quick ...DONT POST YOUR COMPRESSION TEST RESULTS, because I'm not asking about what you got. I'm just asking if my numbers are ok to boost, or if the numbers call for a rebuild ? For those who can reply to my questions, thanks alot
Old Jan 9, 2005 | 01:30 PM
virusiidx's Avatar
they look ok to boost, how much psi to you plan to?
Old Jan 9, 2005 | 01:37 PM
NJIN BUILDR's Avatar
Default Re: JUST did compression test....Can I boost on these number, or should I rebuild ? (Eclipse spanker
That's a lot of mileage to start boosting a gsr.With the high compression ratio you will not be able to boost it much before the rings give up.This would be a good time to lower the cr and get some fresh rings and bearings in there.
Glenn
Old Jan 9, 2005 | 01:38 PM
virusiidx's Avatar
wow i didnt see the milage, but those are still good compression results for that many miles, did you ever have a rebuild?
Old Jan 9, 2005 | 02:04 PM
95BlkGSR's Avatar
Default Re: (virusiidx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx &raquo;</TD></TR><TR><TD CLASS="quote">wow i didnt see the milage, but those are still good compression results for that many miles, did you ever have a rebuild?</TD></TR></TABLE>
i wanna no too...those are good #'s for a 190,000mile car
Old Jan 9, 2005 | 06:09 PM
MikeTV
Guest
Posts: n/a
Default Re: (95BlkGSR)
I haven't ever rebuilt the motor, the previous owner was super **** with taking care of the car, and I am super **** with it also (the only time I beat the car is on the weekends at the races. Daily driving, it never sees past 3500 rpm).
to virusidxx, I plan on running 8 lbs right now, but even at that boost level do you think its only a matter of time before the rings give out, or can I get buy with these numbers running 8 lbs ?
Old Jan 10, 2005 | 05:51 AM
MikeTV
Guest
Posts: n/a
Default Re: (Eclipse spanker)
moday morning bump
Old Jan 10, 2005 | 06:42 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclipse spanker &raquo;</TD></TR><TR><TD CLASS="quote">I haven't ever rebuilt the motor, the previous owner was super **** with taking care of the car, and I am super **** with it also (the only time I beat the car is on the weekends at the races. Daily driving, it never sees past 3500 rpm).
to virusidxx, I plan on running 8 lbs right now, but even at that boost level do you think its only a matter of time before the rings give out, or can I get buy with these numbers running 8 lbs ?</TD></TR></TABLE>
Hmm I've been redlining mine at least once a day probably for the past 100K miles. Mine is about to hit 190K also, still runs great. Those are great numbers, hope mine would register something like that.
Old Jan 10, 2005 | 07:08 AM
CNSK's Avatar
number looks good.....
I did mine last year...came out 225,220,220,225
then yesterday when I did mine again.....
came out....
#1-180
#2-220
#3-220
#4-140
95 gsr with 180k.....
Old Jan 10, 2005 | 10:04 AM
teknoracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">number looks good.....
came out....
#1-180
#2-220
#3-220
#4-140
95 gsr with 180k.....</TD></TR></TABLE>
Thats not good. Something is defintely wrong with your #4 cylinder. They should all wear out evenly.
For the original poster, lower the compression and boost it.
Old Jan 10, 2005 | 11:44 AM
95BlkGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing &raquo;</TD></TR><TR><TD CLASS="quote">
For the original poster, lower the compression and boost it. </TD></TR></TABLE>
Yea # 4 looks a lil weird...might wanna check that out
Old Jan 10, 2005 | 11:51 AM
SHystrdyGSRtdy's Avatar
even on newer lesser mileage cars, the rings can still give out
89hatchy
Jun 18, 2007 06:45 PM
chriskona
Sep 25, 2006 07:34 AM
Silverbullet86
Feb 10, 2006 04:12 PM
AccordCD5
Oct 14, 2005 01:10 PM
xonn
Apr 10, 2003 10:55 AM
