how to remove secondaries?
Old Jan 9, 2005 | 12:51 PM
hOndafienD 04's Avatar
Default how to remove secondaries?
as the title says...how do you do it? i took out my upper half of the manifold off today and i couldnt figure out how to remove te secondaries....can any1 please help? thanx
Old Jan 9, 2005 | 01:53 PM
SKDRCR's Avatar
Default Re: how to remove secondaries? (hOndafienD 04)
You have an h23 right?
Why would you want to remove the secondaries?
Old Jan 9, 2005 | 02:16 PM
matix's Avatar
Default Re: how to remove secondaries? (SKDRCR)
Take the upper part off. Then its just a plate that you pull up on and it should slide off. It might be a little tuff bc the gasket usually sticks.
Old Jan 9, 2005 | 02:51 PM
just take out the plate and bolt the upper half right onto the lower half? damn...thats easy i thought you took the butterflies out...dumb me...thanks anyways....and im removing them just to try thing out
Old Jan 10, 2005 | 03:30 PM
bump for more anwsers
Old Jan 10, 2005 | 03:44 PM
Quick99Si's Avatar
The diaphram might get stuck on the FPR depending on what fuel rail you're using... mine did. A new gasket might be a good idea, I belive they're the same part (top and bottom gasket) so you only need one.
Also, the lost plenum volume might have a negative impact on head flow.
Adi
Old Jan 10, 2005 | 04:29 PM
so head flow would be decreased? i thought it would increase since there is less **** disturbing it....
im using oem fuel rail will it clear it? i have an aem coming in anyways...
Old Jan 10, 2005 | 05:00 PM
prelittlelude's Avatar
you just remove th plate and then put the top part of the intake mani back on,
i can deffinatlye say this is going to hurt your bottom end, and any gains up top are going to be small if any.
honda put the butterflies in for a reason.. just remember that
Old Jan 10, 2005 | 05:10 PM
Speedra500's Avatar
Default Re: how to remove secondaries? (prelittlelude)
you just pull it off like everyone said, however removing the plate shortens your runner length which leads to less volume which is equal to less mass which is less force which means your intake charge has less force coming into the combustion chamber so after BDC it will not continue to force as much air into the cylinder, I also removed my butterflys but i would not recommend it for most people especially with an h23, the only reason I have mine removed(which i might not even keep it that way) is to see if there are any gains to be made on a highly modified setup on the top end
Old Jan 10, 2005 | 05:11 PM
Quick99Si's Avatar
Default Re: (hOndafienD 04)
I don't know much about intake manifold sizing except that it's very complex, and that small changes runner or plenum shape/length/volume can have tremendous effects on engine output characteristics.
In theory though, the lack of butterflies should cause for less restriction and some top end gains. BUT what if that same restriction causes a kind of turbulance that results in more efficient filling of the combustion chamber and better fuel atomization?
Still though, you spend less than 1% of you time above 6000rpm and a lot more under 3500rpm, so why sacrifice city driving? Just my two cents.
Adi
Old Jan 10, 2005 | 05:49 PM
good point, but i just wanna try it and see....
Old Jan 10, 2005 | 05:51 PM
Sam1am26's Avatar
I removed my butterflies but I did not remove the plate, just the individual flaps so that I would not lose plenum volume...
Old Jan 10, 2005 | 05:52 PM
^^^ thats what i thought was supposed to happen...how did you remove the butterflies?
Old Jan 10, 2005 | 05:56 PM
satan_srv's Avatar
horrible idea. you say you just want to 'see' ....gonna dyno that?
Old Jan 10, 2005 | 06:01 PM
no......not gonna dyno....
Old Jan 10, 2005 | 10:31 PM
PrettyLude's Avatar
https://honda-tech.com/zerothread?id=1089260
Old Jan 11, 2005 | 02:51 AM
killer hatch's Avatar
we did this to my boys accord with a 22. we got a little bit more top end, no effect on the bottom end. it does suck up more gas though. not needed really just port and polish the head and port match the manifold to the head. get your throttle body bored this is more money but bigger gains.
95-EX
Oct 31, 2012 07:48 PM
TravisBiggie
Jun 7, 2012 02:27 PM
zccr-xsi
Nov 11, 2007 04:14 PM
boosted ek
Jun 27, 2005 07:01 PM
kinvid22
Jul 13, 2004 11:14 PM
