Headgasket Upgrades For High Boost?
Old Jan 7, 2005 | 10:09 AM
W O T's Avatar
Default Headgasket Upgrades For High Boost?
Just wonderring some opinions on head gasket selection.
I plan on running a D16A6 @ 18psi daily within 2 months. Internals are built to **** with everything in the block n head except sleeves. MSD 6 BTM Ignition. Ive got ARP head studs and Ill be tuning with Turboedit on 93 octane and the car is driven about 20miles daily.
I was planning on using just a stock D16A6 headgasket because they are the cheapest and thickest (10:1 compression is where Im at with it)
But I dont want to be pulling the head every week because the sucker popped
Thanks
Old Jan 7, 2005 | 10:11 AM
DefiantGSR's Avatar
Default Re: Headgasket Upgrades For High Boost? (W O T)
you should be fine. just be sure you torque the head studs correctly
a little copper spray wouldn't hurt either.
Old Jan 7, 2005 | 10:13 AM
Bulldogg83's Avatar
Default Re: Headgasket Upgrades For High Boost? (DefiantGSR)
stock headgasket and copper spray is the way to go.
Old Jan 7, 2005 | 10:59 AM
W O T's Avatar
Default Re: Headgasket Upgrades For High Boost? (Bulldogg83)
Does anyone even know why people use copeerspray?
Ive read in a few threads its good for nothing except making a huge mess when your gasket blows that takes forever to scrape clean....
Old Jan 7, 2005 | 11:02 AM
Bulldogg83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone even know why people use copeerspray?
It helps take out any imperfections that might be in the block or the head which helps seal the gasket better.
Old Jan 7, 2005 | 03:01 PM
PrettyLude's Avatar
stock is best
Old Jan 7, 2005 | 03:16 PM
W O T's Avatar
Default Re: (PrettyLude)
stock it is!
Old Jan 7, 2005 | 05:22 PM
SickAssLy's Avatar
Default Re: (W O T)
cosmetic headgaskets are good too!
Old Jan 7, 2005 | 05:26 PM
rextec's Avatar
all you use to get copper spray off is a rag and some brake cleaner, no big deal.
ekhondahudson
Mar 17, 2014 03:46 PM
aemciv
Jun 21, 2005 05:09 PM
D-meet07
Nov 4, 2004 06:29 PM
b18cx
Jun 10, 2004 03:31 PM
Ri5e
Sep 9, 2002 01:13 PM
