Which is a better head D16z6 or D16y8 ??
Old Jan 6, 2005 | 11:24 AM
wushubrian's Avatar
Default Which is a better head D16z6 or D16y8 ??
Okay currently I have a 97 civic DX hatchback which has a d16y7 non vtec motor. I want to change to a vtec head but am debating if a D16z6 head or D16y8 head would be better. Any suggestions on which head would work better. I hear the z6 has better flow but is harder to find with low miles. I hear the y8 is a more reliable head and easier to find. I also plan on turboing it later on. All recomendations and suggestions are welcome. Thank You.
Old Jan 6, 2005 | 11:26 AM
Luserkid's Avatar
Default Re: Which is a better head D16z6 or D16y8 ?? (wushubrian)
I would do the y8 due to no OBD BS
Old Jan 6, 2005 | 11:30 AM
a1320honda's Avatar
Default Re: Which is a better head D16z6 or D16y8 ?? (Luserkid)
if i rememer right the y8 head has better designed quench zones that help to prevent detonation. i think thats the only real advantage, i could be wrong though
Old Jan 6, 2005 | 01:33 PM
wushubrian's Avatar
BUMP... Still a little unsure on which one to go with. Any more opinions?
Old Jan 6, 2005 | 01:42 PM
civiccpedx's Avatar
the z6 head flows much more freely, but if you just stick with the y8 that would prolly be best so you dont have to deal with any OBD coversion, like luserkid stated
Old Jan 6, 2005 | 01:46 PM
wushubrian's Avatar
Default Re: Which is a better head D16z6 or D16y8 ?? (civiccpedx)
Alright i think i'll go with the y8 head. Any suggestions on where to pick one up. Looking for one with under 35,000 miles on it. I know there are two for sale on Honda-Tech. Any websites that just sell heads?? Also, what things should be included when you buy a head. Thanks for the information.
Old Jan 6, 2005 | 02:04 PM
Itz Darave's Avatar
if your going turbo, i would stick with the non vtec head. get a y8 intake manifold... and just turbo it. and up the boost, you'd save money too... and you wouldnt have to spend extra money on a ecu and engine harness.
Old Jan 6, 2005 | 02:08 PM
civicx98's Avatar
Default Re: (Itz Darave)
The Y8 head is a much better design. It is a pent roof design, which will flow better.
Old Jan 6, 2005 | 02:17 PM
mwieczorek43's Avatar
Default Re: (civicx98)
The Z6 flows better.
The Y8 will yeild a higher compression ratio.
Its your choice.
If your going turbo then... you have your answer (Y8).
If your going all motor then.... you still have your answer (Z6).
edit- They had a detailed post about this with pics and tests to back it up.
Old Jan 6, 2005 | 03:00 PM
cnyej1's Avatar
Default Re: (mwieczorek43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 &raquo;</TD></TR><TR><TD CLASS="quote">The Z6 flows better.
Its your choice.
.</TD></TR></TABLE>
Wouldnt this be the other way around?? If all motor then Y8 since it yields higher compresion, which is better for all motor and worse for turbo, and the z6 would be better for turbo because of the lower compression and good flow?
Old Jan 6, 2005 | 04:24 PM
wushubrian's Avatar
Anymore opinions or suggestions about this setup?
Old Jan 6, 2005 | 04:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">Wouldnt this be the other way around?? If all motor then Y8 since it yields higher compresion, which is better for all motor and worse for turbo, and the z6 would be better for turbo because of the lower compression and good flow? </TD></TR></TABLE>
Yeah, thats what I meant... Im an idiot.
You know what I meant.
bobbyx0r
Jul 30, 2011 11:47 AM
SpdKilz23
10
Apr 11, 2009 02:48 PM
Dasfinc
Sep 26, 2007 08:14 PM
98jdm_coupe
Apr 15, 2004 09:28 PM
SIcoup
Nov 28, 2003 12:36 PM
