idle at 3k?
Old Jan 5, 2005 | 08:19 PM
B18C1 Civic EG's Avatar
Default idle at 3k?
hey i got a 95 vx hatch with a 95 gsr motor. everything seems to run good except recently whenever my car is cold, it idles around 2500-3000rpm for about 10min and occasionally jumps between 1000-3000 when warming up. anyone know what that might be coused from? also is it normal to get 25-30 mpg with a gsr motor? i have a stock fuel pump from the vx so would that be holding the fuel back? any information would be appriciated, thenks alot.
Old Jan 5, 2005 | 08:46 PM
eK9aT10pSi's Avatar
Default Re: idle at 3k? (B18C1 Civic EG)
just for the safe side you should up the fuel pump, ill bet with the vx fp, your running close to or already at lean. the idle issue could be the iavc or the fitv
Old Jan 5, 2005 | 10:30 PM
Default Re: idle at 3k? (eK9aT10pSi)
problem fixed. cleaned the fitv and adjusted it and it idles nice now. thanks alot for the help.
mayfly
Jun 2, 2010 03:10 PM
B18C1 Civic EG
Jan 5, 2005 10:39 PM
GSRwBOOST
Jan 7, 2002 11:44 AM
