OBD-I to OBD-II
Old Jan 5, 2005 | 07:29 PM
EJ20's Avatar
Default OBD-I to OBD-II
What would i take to convert my obd-1 95 gsr longblock to my current obd-II gsr? I heard u just plug it in with my current obd-II wiring harness?
Old Jan 5, 2005 | 08:17 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: OBD-I to OBD-II (EJ20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ20 &raquo;</TD></TR><TR><TD CLASS="quote">What would i take to convert my obd-1 95 gsr longblock to my current obd-II gsr? I heard u just plug it in with my current obd-II wiring harness?</TD></TR></TABLE>
No...you cannot just plug it in because...remember an OBD II motor has more sensors than an OBD I motor. And also, the fact that some of the wires (distributor, alternator, etc.) are in different configurations using different connectors. This will cause a disaster in your electrical system..indeed.
Old Jan 6, 2005 | 01:02 AM
EJ20's Avatar
Default Re: OBD-I to OBD-II (NVturbo)
So which parts would i have to swap from my old obd-ii motor? (distributor, alternator, etc.) I'm in the process of doing this right now and need guidance.
thanks
Old Jan 6, 2005 | 06:46 AM
VN712's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ20 &raquo;</TD></TR><TR><TD CLASS="quote">So which parts would i have to swap from my old obd-ii motor? (distributor, alternator, etc.) I'm in the process of doing this right now and need guidance.
thanks</TD></TR></TABLE>
Why don't to just buy a obd2-obd1 conversion harness and an obd1 gsr ecu and be done with it. Seeing where you are located, you are able trying to put an older motor into a newer car so...doing this wouldn't be illegal in your area.
Old Jan 6, 2005 | 06:48 AM
VN712's Avatar
Default Re: OBD-I to OBD-II (B20ZLS)
Btw...it would cost more time and money to do what you are doing for your information.
Old Jan 6, 2005 | 09:45 AM
EJ20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20ZLS &raquo;</TD></TR><TR><TD CLASS="quote">Why don't to just buy a obd2-obd1 conversion harness and an obd1 gsr ecu and be done with it. </TD></TR></TABLE>
Alright I found a conversion harness for 100 on ebay http://cgi.ebay.com/ws/eBayISA...photo
Found this ecu: http://www.ecutuning.com/OBD1ECU.php
From what you're saying I just get those two pieces and use my existing obd II harness plug n play(somewhere I read u have to rewire) ?
Modified by EJ20 at 11:42 AM 1/6/2005
Old Jan 6, 2005 | 11:09 AM
VN712's Avatar
Modified by EJ20 at 11:42 AM 1/6/2005</TD></TR></TABLE>
YES, you are on the right track. With the obd1 longblock that you got, use your existing harness on you old motor, reuse your obd2 dizzy, reuse your obd2 altenator, and reuse your obd2 injectors. The plugs for the knock sensor and secondary o2 will not be plug in, but that is fine and you won't throw a cel. Everything else is plug and play. In the short and long runs ,you are benefiting.
BTW..the harness can be had for 80 shipped..that is how much i got mine
ECU are about 100-150 shipped.
Converting to obd1 is a smart idea while you are at it.
Ask if you have any more question
Old Jan 6, 2005 | 11:11 AM
VN712's Avatar
btw...becareful when purchasing a conversion harness that you get the right one.
96-98 is obda
99-00 is obdb
Good luck to you
Old Jan 6, 2005 | 01:17 PM
EJ20's Avatar
thanks alot man
Whered you get your wiring harness? If I cant find a differnt one...I just might get that "bumblebee" harness for 100 at ebay.
And I'm having a hard time trying to find ecu's ...I did find that "custom" one for about 180...
thanks again
Old Jan 6, 2005 | 01:46 PM
Blown90hatcH's Avatar
https://honda-tech.com/zerothread?id=997093
Sent you a PM.
JAson
http://www.JKobdconversionharness.com
Old Jan 6, 2005 | 02:39 PM
EJ20's Avatar
Default Re: OBD-I to OBD-II (Blown90hatcH)
looks good
now for an ecu...
Old Jan 6, 2005 | 03:27 PM
charjacq's Avatar
New User
I have all applications in stock as well as conversion harnesses if you need one. I'll package it all up.
info@ecutuning.com
Old Jan 7, 2005 | 07:44 AM
ProJectCvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=997093
Sent you a PM.
JAson
I got this harness too..work great on my brother hatchie. As for the ecu..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ20 &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot man
thanks again </TD></TR></TABLE>
Search in the classified and type in p28...i got 30 hit. Good luck
2Point2EH2
Aug 26, 2006 06:36 PM
advanracing62
Mar 15, 2004 09:59 AM
boomslang
Jul 25, 2002 12:21 AM
Phoenix GSR
Mar 11, 2002 03:45 AM
dho311
Feb 21, 2002 01:17 AM
