OBD II to OBDI alternator wiring?
I have an OBDII engine harness and need to convert the plug to OBDI for the alternator- does anyone know which wires on the OBDI alt go to the wires on the OBDII harness?
Re: OBD II to OBDI alternator wiring? (advanracing62)
you cant do it and keep the harnesses you have to hardwire it obd1 is 2 harness obd2 is 1
its mostly matching colors from both sides i dont remember the actual colors but i know that the whole thing is sheilded in a ground like a coax cable so you have to wid that up and solder it its been a while sorry i cant be more help
Re: OBD II to OBDI alternator wiring? (integra6650)
well two of the colours match up on the plug, the other two don't- I guess I'll try it one way and see if it works, if not then it must be the other...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 »</TD></TR><TR><TD CLASS="quote">Got it figured out- Thanks for all the help </TD></TR></TABLE>
Did you learn a lot from yourself on here.
