ECU Qustion ? 93 dx civic and want to do a ls swap..
i have a 93 DX civic hatch and em looking to get a 99ls obd2 swap. What ecu should i go with? and i plan on going turbo. 1) should i use my dx ecu and get it chippet to ls specs.? 2) should i get a 92 to 95 ls obd1 ecu? 3)p28 rechipped will it work even thow i have no VTEC will it be easyer one to use for this swap bec i herd u dont need to wire up knok off sensors? dont realy get get it just herd it. 4) bec im going turbo does this mean i should use some thing diffent? thanks for your time!!!!
get an obd1 ls dizzy and injectors, and you may need an altermator unless you know how to repin it, and use the dx harness, with a 94-5 ls ecu you will be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">get an obd1 ls dizzy and injectors, and you may need an altermator unless you know how to repin it, and use the dx harness, with a 94-5 ls ecu you will be fine.</TD></TR></TABLE>
if you get a usdm motor with a harness, you can just plug it right in to the car harness and us a obd1 p75 ecu.
ted
Feb 14, 2005 03:30 PM
