Sensor help on first gen B16!!!
Old Jan 4, 2005 | 02:16 PM
B16CRXT's Avatar
Default Sensor help on first gen B16!!!
Ok, I was looking in my engine bay earlier (the B16 was put in my car before I got it) and there are a lot of wires that are showing/looking ghetto as hell. So, I started tracing some of them. One in particular that I cant trace just ends and it dangling Another is a single wire going to some sensor just below the Intake manifold. It has a green plug. Two more sensors just below that, right next to the oil pressure sensor (what are these?). And what is the sensor below the distributor? and both plugs below the vtec solenoid are...????
TIA!!
Old Jan 5, 2005 | 05:10 AM
B16CRXT's Avatar
Default Re: Sensor help on first gen B16!!! (B16CRXT)
bump.
Old Jan 5, 2005 | 04:38 PM
B16CRXT's Avatar
Does anyone know?
Old Jan 5, 2005 | 04:43 PM
dcvt16's Avatar
the one right under the intake manifold(green) is knock sensor. there is also some coolant sensor bacl there as well(2 wire), under the vtec sol. are the coolant temp sensor and vtec oil pressure switch.
Old Jan 5, 2005 | 07:30 PM
B16CRXT's Avatar
Default Re: Sensor help on first gen B16!!! (dcvt16)
huh?
There is the green plug under teh IM, then two more sensors that look just like the one that is under teh distributor (btween the upper rad hose connection to the block and the hose that goes to the heater controls), and the green plug and white plug near the vtec solenoid.
Are you saying that 2 wire green plug under the IM is the knock sensor?
Thanks for the reply btw.
Anyone else?
Old Jan 6, 2005 | 06:30 AM
GULLIE EG's Avatar
is the engine in that CRX you have pictured? Is your check engine light on? Also what engine harness are you using? If it was put in before you got the car, someone could have hacked any gsr/ex harness and you used that, which would explain all the extra plugs
Old Jan 6, 2005 | 07:03 AM
B16CRXT's Avatar
Default Re: Sensor help on first gen B16!!! (GULLIE EG)
well the plugs arew actually attatched to the engine. I'm pretty sure when they installed it they used the stock CRX Si engine harness and added a few wires...It just looks very sloppy and I cant tell whats what and I would like to know what each of the sensors are.
EDIT: No CEL and yes its in that CRX in my avatar.
dannyseps
Feb 13, 2012 04:58 PM
mikegeezy
Oct 4, 2009 10:51 AM
orioncivic
Sep 3, 2008 07:50 PM
foress_89
Jan 15, 2008 03:58 PM
92hybridhhatch
Feb 12, 2002 12:34 PM
