Civic VX ecu chippable??
Old Jan 8, 2002 | 05:23 AM
FLCivic's Avatar
Default Civic VX ecu chippable??
Is the civic vx ecu chippable to dohc spec like th P28?? The vx has vtec also.
Old Jan 8, 2002 | 05:33 AM
stkd16z6's Avatar
Default Re: Civic VX ecu chippable?? (FLCivic)
Yes, they can be chipped... do a search HAHAHA..... Look for eg6ajk on this board he sells the chip for like $40 all you have to do is remove the old chip and solder the new one in.
[Modified by stkd16z6, 2:36 PM 1/8/2002]
Old Jan 8, 2002 | 07:24 AM
FLCivic's Avatar
Default Re: Civic VX ecu chippable?? (stkd16z6)
Can anyone back this up?? I don't know if I can trust this dude with a stock d16 from Jacksonville, FL.
What up B?
Old Jan 8, 2002 | 12:33 PM
Katman's Avatar
What up B?
uhh..not ALL VX ECU's work right when reprogrammed. Supposedly there's 2 types of VX ECU's, I've only come across one (forgot the motherboards part number) and I've tested it out numerous times and it runs really funky. Check light goes on and off at weird times, the fuel pump stays on when the ignition is turned onto the second click (usually you can hear the fuel pump kick on, then kick off) well it doesn't with the VX ECU, it constantly stays on...weird..
Then there's the other type of VX ECU that is actually on the same platform (motherboard) as a P28 ECU....that's the one that's chippable with no problems. I dunno if it's a Canadian only model or what -- but I've yet to come across this VX type....
I'll snap some pics so you can match up your VX ECU to the crappy version, just to see which version of VX ECU you have...
email me privately if you'd like to pursue more info on this......
[Modified by Katman, 1:34 PM 1/8/2002]
Old Jan 8, 2002 | 04:14 PM
juicy.koreans.suck's Avatar
Default Re: Civic VX ecu chippable?? (CrazyScott)
were talkin about to continuin to use your ecu when you swap a motor.
integra_speed
Dec 18, 2008 06:19 PM
JDM96SpecCTR
Dec 25, 2004 08:57 AM
joepark2001
17
Mar 4, 2004 04:53 AM
Desperado
Apr 15, 2003 12:51 PM
gsrvx
Jan 31, 2003 07:26 PM
