Trans question
Old Jan 1, 2005 | 03:41 PM
jdonley3000's Avatar
Default Trans question
I am getting a swap for my del sol. It origonally is Auto, but the swap comes w/ a manuel trans. Of course i would prefer a manuel, but i was wondering what else i would have to do to change Auto to Manuel.
Old Jan 1, 2005 | 03:53 PM
Sir Del Slow's Avatar
Default Re: Trans question (jdonley3000)
if your goin to swap go type r lsd you wont regret
Old Jan 1, 2005 | 04:00 PM
civictildeath's Avatar
Default Re: Trans question (Sir Del Slow)
is it hydro tranny or cable??
Old Jan 1, 2005 | 04:10 PM
Default Re: Trans question (civictildeath)
i'm not sure, whitch one would be better, but yeah it does have LSD
Old Jan 1, 2005 | 04:12 PM
hydro is better i think. what year is it you know??
Old Jan 1, 2005 | 04:28 PM
gt30typer's Avatar
Okay here is the list. it is not too bad
1. Motor mount that is spot welded to the frame on the tranns side out of a manual del sol/ civic/ integra, you can buy it at honda or get it from a junk yard.
2. Clutch slave cylinder/ Clutch master cylinder and lines/brackets
3. Pedal assembly out of a manual
4. ECU , your getting a swap so it does not really matter
5. Gauge cluster if you have money
6. Shift boot/ shift ****
All of these parts should be easy to find
Manual is the only way to go, down with automatics
Old Jan 2, 2005 | 10:06 AM
Default Re: Trans question (gt30typer)
Thanks alot, now its time to check Ebay and the junkyards for that other stuff. ya and i know manuel is the way to go, i was getting killed off the line by any manuel car.
D16vtecfreek
May 7, 2009 11:19 PM
jakeypoo12
Aug 14, 2008 06:52 AM
1994delsolvtec
Mar 24, 2007 08:51 AM
rcaryl
Apr 8, 2005 11:58 AM
blue_hatch
Mar 17, 2005 10:45 PM
