Losing power?
Old Dec 31, 2004 | 09:24 PM
aznsins88's Avatar
Default Losing power?
Help guys! After getting my spark plugs, distributor cap, head gasket, oil pump, and an oil change, my car seems to have lost power! Anyone kno what and/or why this could be???
Old Dec 31, 2004 | 09:46 PM
fastrunner's Avatar
Default Re: Losing power? (aznsins88)
new thicker head gasket= lower compression.
messed up ignition timing from distributor(if you changed cap and rotor.)
Old Dec 31, 2004 | 09:57 PM
aznsins88's Avatar
i didnt get thicker head gaskets so the compression should be the same, as for the distributor i only changed the cap so anymore thoughts?
Old Jan 1, 2005 | 12:03 AM
aznsins88's Avatar
good night bump
Old Jan 1, 2005 | 07:19 AM
Racermech's Avatar
Wrong spark plug gap? Did you notice the power loss right away or was it after a couple hundred miles? I did the same on my car and I fould a plug within a couple hundred miles, pulled the plugs, found the bad one replaced it and it was fine. Sometimes a plug can be bad right out of the box.
Did you change the rotor?? If not change that see if it helps. I think they are only about $10
KoukiMonstr
Jan 2, 2014 07:59 AM
civicxxman
Apr 27, 2008 01:52 PM
FlyingDaggers
Jan 30, 2008 06:19 PM
CiViCgT32
Mar 17, 2007 12:21 PM
shadowstylz
Sep 2, 2003 06:23 PM
