No spark!?!?
Old Mar 16, 2007 | 02:15 PM
CiViCgT32's Avatar
Default No spark!?!?
i finished putting my car back together the other day and when i tried to start it today it didnt work. It turns over but there doesnt seem to be a spark comin from the plugs. i have the msd distributor cap and blaster coil hooked up. what could be the problem???
any help would be great.. im gettin tired of workin on this car..
Old Mar 16, 2007 | 03:52 PM
hatchling37's Avatar
Default Re: No spark!?!? (CiViCgT32)
Check connections. Any CEL's? Maybe your dizzy took a dump. There are a bunch of possibilities, there chief. Try to be more thorough. What did you do to it? We have no idea what you've done in your garage the past couple of days.
Old Mar 17, 2007 | 12:10 PM
CiViCgT32's Avatar
Default Re: No spark!?!? (hatchling37)
no CEL's. well what i did was replace the head gasket. I checked all the connections and it seems fine. I checked for spark by stickin the spark plug into the wire and touchin it on a metal but didnt see a spark. what doesnt make sense is that before i replaced the head gasket the car started, but after it wont spark. Could it be my MSD distributor and blaster coil??
oh and my battery was drained but i tried to jump the car and still no go
Modified by CiViCgT32 at 2:54 PM 3/17/2007
Old Mar 17, 2007 | 12:19 PM
standbackimapro's Avatar
Distributors Go bad without any symptoms most of the time,
For instance, I did a Compression test on a civic once, car was running and started fine 2 minutes earlier, the test was done, and the car wouldnt start, no spark, Distributor was bad...
Old Mar 17, 2007 | 12:21 PM
CiViCgT32's Avatar
Default Re: (standbackimapro)
should i jus go with a stock distributor or should i fix the one i got?
anyone else have any opinions/suggestions?
Modified by CiViCgT32 at 1:52 PM 3/17/2007
gottagofaster
Oct 22, 2005 04:50 PM
iNetForce
Feb 29, 2004 09:59 AM
phildeez
Mar 15, 2002 07:22 PM
