My Oil return line doesnt look right?????
Old Dec 30, 2004 | 10:50 AM
ebpcivicsi1234's Avatar
Default My Oil return line doesnt look right?????
I dont know what i can do to fix this or maybe its ok but it is hitting my piping any one know what i should do or will it be ok?
Old Dec 30, 2004 | 10:52 AM
mooook's Avatar
Default Re: My Oil return line doesnt look right????? (ebpcivicsi1234)
im sure you'll be OK. As long as its not your downpipe hitting that it wont melt or anything like that. The IC piping shouldnt flex to much in order to bang against your return line.
Old Dec 30, 2004 | 10:58 AM
Default Re: My Oil return line doesnt look right????? (mookvtec)
i mean i really have to bent the ss line to get it to thread on the oil pan fittings.once is all tightend down the ss line doesnt move an inch i just hope the shifting of the motor and stuff wont do anything to it....also i wasnt going to get the vacumme maifold or whatever its called for my oil lines but iam going to now but whats the best way to do it just run a ss line off the block to the manifold and have my oil pressure gauge,feed line,stock sensor run off of that...i have already broke a T off in the block before and i dont want that to happene agian
Old Dec 30, 2004 | 11:46 AM
D-t's Avatar
D-t
IDK.
I'm thinking it should be more vertical to return the oil into the pan.
It looks as if the return comes straight down, then bang makes a 90 degree turn but angles a bit up. Might be the angle of pics.
Turbo vet's can chime in with a better response.
Old Dec 30, 2004 | 12:08 PM
B18C1CYA's Avatar
i think it will be fine , but iff your worried just get 2 45's and put then on the ends insted of the straights,
Old Dec 30, 2004 | 12:27 PM
Frozen E's Avatar
H-T White Ops
Any way you can just cut about an inch or so off your charge pipe where it connects into your turbo discharge to have it run a little higher? That would fix your problem.
Either that or run a 45* fitting off your fitting on the pan towards the downpipe and have the return line meet up with it further over.
Old Dec 30, 2004 | 12:40 PM
mike1114's Avatar
Default Re: (IslandSi)
getting a fire sleeve will help also. I have one of these on my return line just in case.
Old Dec 30, 2004 | 02:14 PM
LoSt is BlaCk's Avatar
Default Re: (mike1114)
you might be able to put a 45 degree fitting off the pan at a different angle...or you can put a small dent in that pipe to clear the line and fitting...
Old Dec 30, 2004 | 04:00 PM
turbosi03's Avatar
Default Re: (LoStMyBoOsT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoStMyBoOsT &raquo;</TD></TR><TR><TD CLASS="quote">you might be able to put a 45 degree fitting off the pan at a different angle...or you can put a small dent in that pipe to clear the line and fitting...</TD></TR></TABLE>
yep, that will make your oil return trip shorter
seems like I didn't even need an SS line...
Old Dec 30, 2004 | 05:21 PM
TunerToys's Avatar
Default Re: (turbosi03)
A 45 off that pan fitting would be something to surely try. I bet it helps out with the drain angle and the clearance.
.02 from Craig
LilCivic04
Aug 18, 2005 08:12 AM
birz
Jun 4, 2004 06:03 AM
G U E C O
Dec 20, 2003 04:51 PM
vtec.dc2
Sep 14, 2003 06:45 PM
Snafu-Si
Jul 2, 2002 07:58 AM
