vafc 2 question
Old Dec 28, 2004 | 06:27 PM
jdm420da6's Avatar
Default vafc 2 question
yeah..yeah...i searched but didnt exactly find what i was looking for....my questions is...what pressure switch is the white and yellow wire go to. PA? oil? vtec oil? and the light blue wire goes to VTC cam signal...is that like the cam angle sensor??
anyway im currently using a pr4 but gettin a pr3/pwo...oh yeah the setup is an ls/vtec in a DA...thanks!!
Old Dec 29, 2004 | 01:57 AM
typesguy's Avatar
the light blue wire is for i-vtec vehicles only so if you don't have a k20 then you don't use the light blue wire
Old Dec 29, 2004 | 10:49 PM
jdm420da6's Avatar
Default Re: (jaydmdc2)
cool...thanks man.
but where does the white and yellow wire go to tho??
Old Dec 30, 2004 | 12:33 AM
Kendall's Avatar
Default Re: (jdm420da6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm420da6 &raquo;</TD></TR><TR><TD CLASS="quote">but where does the white and yellow wire go to tho??</TD></TR></TABLE>
One of the MAP signal wires needs to be cut coming out of the ECU and the white and yellow are hooked up to either end of the cut wire. I just can't remember which MAP wire it is, and whether the yellow or white is supposed to go on the ECU side of the cut wire.
Apex'i USA's website has the wiring diagrams on it.
Old Dec 30, 2004 | 08:45 AM
jdm420da6's Avatar
Default Re: (Kendall)
thats all i needed to know...thanks man ur the ****!!
Old Jan 1, 2005 | 07:31 PM
jdm420da6's Avatar
so now i wired everything up and now i got a MAP sensor MIL and my car keeps dying after about a minute....what the **** is going on...is the yellow and white wires really suppose to go to the MAP?
when i was at sensor check mode....pressure was at 0kpa
i dont even know what sensor number its suppose to be set at because the instructions dont tell jack ****.
whoever really knows what those yellow and white wires are suppose to go and who can tell me what sensor number i should be at help me out please...i dont understand what the **** im doing wrong.
Old Jan 2, 2005 | 09:06 AM
jdm420da6's Avatar
n/m figured it out myself like i always do
Sleepy_Red_hatch
Oct 7, 2005 10:23 PM
SleepnCiViC
16
Oct 30, 2004 11:38 PM
jisecup
Jul 9, 2003 02:53 PM
InTeGrA B18b1
Jun 24, 2003 10:45 AM
Maverick77
Nov 22, 2002 09:21 PM
