VaFc on LS Help
Old Jun 23, 2003 | 08:20 PM
InTeGrA B18b1's Avatar
Default VaFc on LS Help
what do i do with the yellow and white wire? i know i dont use the pink,purple and blue wire. And also my vafc cant keep memory help, thanks man
Old Jun 23, 2003 | 08:45 PM
Type-GS-R-Turbo's Avatar
Default Re: VaFc on LS Help (InTeGrA B18b1)
yellow and white are the most important wires. They are the map sensor input and output wires. Lemme check my car to make sure I'm giving you the right info. White is map input to the apexi, Yellow is map output from the apexi to the ECU.
Cut the White/Yellow wire going to the ECU, that's the map signal. the White/yellow from the chassis hooks into the white, yellow goes into the white/yellow to the ECU.
Old Jun 23, 2003 | 11:40 PM
the memory works after a couple hours but what wire does the white and yellow go to on my ls? everything is working fine now and just curious if its needed.
Old Jun 24, 2003 | 08:39 AM
anyone help?sometimes the memory goes away why?
Old Jun 24, 2003 | 09:38 AM
redtegger03's Avatar
yellow wirse is the airflow/pressure signal out....the white wire is airflow/ pressure signal in
Old Jun 24, 2003 | 09:39 AM
Default Re: (redtegger03)
on the ecu the yellow/white wire is the map signal?
Old Jun 24, 2003 | 10:32 AM
romeo619romeo's Avatar
Default Re: (InTeGrA B18b1)
you might have taped into the wrong power wire in the ecu..
Old Jun 24, 2003 | 10:45 AM
Default Re: (romeo619romeo)
Is the Pressure signal and map signal the same?
soulo
Feb 27, 2008 09:03 AM
jdm420da6
Jan 2, 2005 09:06 AM
spooned out
Aug 5, 2003 09:37 AM
xXx Justin xXx
Jun 18, 2003 09:49 AM
