wiring up tachometer
Old Dec 1, 2003 | 04:54 PM
SleepnCiViC's Avatar
Default wiring up tachometer
k guys i need to know which wires go where, im installin an auto meter tach and shift light on my b18c5 in my EK
Old Dec 1, 2003 | 04:59 PM
ghettochild's Avatar
Default Re: wiring up tachometer (SleepnCiViC)
green wire- goes to your dizzy (the blue wire)
black wire- is ground
white wire- goes to your parking light switch
red wire- goes to your ignition (the big fat white wire)
hope this helps
Old Dec 1, 2003 | 05:05 PM
by dizzy you mean the wires coming from the distrbutor cap? where is the ignition wire (fat white wire) and where is the parking light switch, sorry im a serious honda noobie, but i dont mind asking questions
Old Dec 1, 2003 | 05:09 PM
TeStUdO's Avatar
Default Re: (SleepnCiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">by dizzy you mean the wires coming from the distrbutor cap? </TD></TR></TABLE>
there is a blue one coming off it
Old Dec 1, 2003 | 05:12 PM
2nd question the only wire i have lying around is speaker wire. will this wire work to hook everything up??
no, the wire for the distributor is in the plug it will be blue wire the only blue wire in the plug, its next the the black and yellow wire. and the ignition wire is in the steering column, its the big white wire that goes to the back of the place where your key goes in your ignition.and sorry i really cant remember what color or which wire for the lights.
Old Dec 1, 2003 | 05:14 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">2nd question the only wire i have lying around is speaker wire. will this wire work to hook everything up??</TD></TR></TABLE>
Please go out and buy some real wire. I would not reccomend speaker wire for this.
Default Re: (ghettochild)
naw man just wait until you get better wire ok, dont use speaker wire
(but use it if your completly broke and desperate)
Old Dec 1, 2003 | 05:55 PM
so im gonna have to pull some of the dash up to get to the white ignition wire??
Old Dec 1, 2003 | 06:03 PM
Pnoymugen's Avatar
Default Re: wiring up tachometer (ghettochild)
You could wire together the red and white wires together and wire them up to the fuse box, to the intruments, just an advice, it could make your wiring easier :-) what i did to mines
Old Dec 1, 2003 | 06:09 PM
yeh thats how i had it on my 240, you know what particular fuse if any??
Old Dec 1, 2003 | 06:28 PM
Pnoymugen's Avatar
yeah, should be the instruments/interior lights fuse
Old Dec 1, 2003 | 06:54 PM
WangChung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">by dizzy you mean the wires coming from the distrbutor cap? where is the ignition wire (fat white wire) and where is the parking light switch, sorry im a serious honda noobie, but i dont mind asking questions</TD></TR></TABLE>
i assume u bought the car with the swap already in it?
Old Dec 1, 2003 | 06:56 PM
B2FiNiTY's Avatar
Default Re: (WangChung)
What kind of wires should one use?
Old Dec 1, 2003 | 07:06 PM
yeh swap was already done
Old Dec 1, 2003 | 09:00 PM
Boosted1999Ek's Avatar
depending on witch car on mine i hooked up my green wire to a wire that is on like a little metal plug thing it is a single blue wire and it is almost write buy where you put you clutch fluid in its right there buy your fire wall but i drive a 99 dx hatch when i hooked mine up to the blue wire on the distributor my tach said it idled at like 6 grand so it just all depends on your year but check your fire wall its the easiest
Old Oct 30, 2004 | 11:38 PM
kali7554's Avatar
Default Re: wiring up tachometer (Boosted1999Ek)
need help i got 97 civic ex cant find the rpm signal help help plz
90_EX_Civic
Mar 21, 2009 07:59 PM
beatthisspeed69
19
Aug 2, 2007 08:46 AM
jayare05
10
Dec 25, 2004 01:12 PM
crx_ef8
Mar 10, 2003 10:47 PM
