Where to mount Inline Fuel Pump?
Old Dec 27, 2004 | 03:03 PM
edgar306's Avatar
Default Where to mount Inline Fuel Pump?
As the subject says, I wanted to know where you guys mount the inline pump? My Brother just put a Turbo Kit on his Integra and he asked me for help installing the Inline Pump. Any Help will be appreciated... Pics would be Great!!!
Edgar
Old Dec 27, 2004 | 03:42 PM
10secivic's Avatar
Default Re: Where to mount Inline Fuel Pump? (edgar306)
I put alot of them down by the gas tank underneath the car right before it goes in to the hard line.
Old Dec 27, 2004 | 05:48 PM
edgar306's Avatar
Default Re: Where to mount Inline Fuel Pump? (10secivic)
Thanks man, I will have to get under there and see how hard it looks... I have seen the hard lines in the car, but have not looked under it... Thanks again!
Old Dec 27, 2004 | 06:35 PM
CAE's Avatar
CAE
HOW DOES THIS INLINE PUMP LOOK LIKE AND HOW MUCH AND WHERE CAN I GET THEM?THANKS
Old Dec 29, 2004 | 02:39 PM
scartail's Avatar
Default Re: Where to mount Inline Fuel Pump? (CAE)
Don't you have to put it after the fuel filter... between it and the fuel rail? I recall reading something like that... Anyhow, I followed suite... and did such... and mounted (zip tied) it to the A/C hard lines... Just under the fuel filter...
I don't like it... I am thinking about mounting it elsewhere...
How long can the lines be to an from the pump? Would that even make a difference...
I'm interested in see where other have mount there also...
edit: I had ask the same question too...
https://honda-tech.com/zerothread?id=966738
This is what someone replied.
Old Dec 29, 2004 | 02:45 PM
11psiTurboSI's Avatar
Default Re: Where to mount Inline Fuel Pump? (scartail)
Why not make your lives easier and get a Walbro GSS-342 HP 255lph "intank" fuel pump for under $100?
Old Dec 29, 2004 | 02:56 PM
MooreBoost's Avatar
Default Re: Where to mount Inline Fuel Pump? (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">Why not make your lives easier and get a Walbro GSS-342 HP 255lph "intank" fuel pump for under $100?</TD></TR></TABLE>
Thats what I would do. But if you do go for an inline mount it the way scartail did.
Old Dec 29, 2004 | 05:11 PM
CAE's Avatar
CAE
Default Re: Where to mount Inline Fuel Pump? (tegunderpressure)
WHAT DOES THIS INLINE PUMP FOR?DO I HAVE TO CHANGE MY STOCK INJECTORS?AND HOW MUCH DO THEY COST AND WHERE TO GET THEM,THANKS
Old Dec 29, 2004 | 05:34 PM
mrbsponge's Avatar
inline pumps suck ***, they only help to get fuel pressure up a bit, 9 times out of 10, they flow alot less volume then your stock unit, AND they will only be fed as fast your intank pump can feed them!!!!! so whats the point, buy a good intank pump for 100 bux, or less and forget about it
Old Dec 29, 2004 | 05:52 PM
MooreBoost's Avatar
Default Re: (mrbsponge)
They probably don't flow much more than stock but what they do do is keep the fuel pressure up for FMU's.
Old Dec 29, 2004 | 08:02 PM
CivicEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">inline pumps suck ***, they only help to get fuel pressure up a bit, 9 times out of 10, they flow alot less volume then your stock unit, AND they will only be fed as fast your intank pump can feed them!!!!! so whats the point, buy a good intank pump for 100 bux, or less and forget about it</TD></TR></TABLE>
Old Dec 29, 2004 | 08:43 PM
crxrocks's Avatar
Replacing the in tank pump in the CRX requires dropping the tank.... blah.
PRO1
Sep 24, 2009 06:28 PM
98AccordEX
Jul 2, 2004 06:51 PM
SpoonyGSR
Mar 22, 2004 02:11 PM
7PSiEF9ZC
Jun 14, 2003 07:38 AM
slwazgsr
Oct 12, 2002 07:37 AM
