tach lead, cluster or engine bay?
Old Dec 27, 2004 | 08:36 AM
dmxsoulja3's Avatar
Default tach lead, cluster or engine bay?
Did you guys use behind the cluster to tap for aftermarket tach, or some connector in the engine bay that someone refers to that I'm still unable to find!! If you could let me know what harness and wire on the cluster of my EG to tap off of you would be the man!
Thanks, Josh
p.s. Just got a Stewart Warner Ultra shiftlite, will post pics after the install.
Old Dec 27, 2004 | 08:44 AM
92 EH2's Avatar
Default Re: tach lead, cluster or engine bay? (dmxsoulja3)
all i know is blue one...idk if that helps at all tho. my friend did his shift light and said he tapped it into the blue wire.
Old Dec 27, 2004 | 08:48 AM
endlesswinterco's Avatar
Default Re: tach lead, cluster or engine bay? (92 Hatchie)
dont tap it off the cluster one, cause its not that accurate. dont take my word but pretty sure that you tap it off the dizzy. not sure which wire though
Old Dec 27, 2004 | 08:50 AM
snatch's Avatar
Default Re: tach lead, cluster or engine bay? (RidinlowHatch)
There is a blue wire just off the firewall on the driver's side of the engine bay. It's a single blue wire, tap into that. It doesn't even go into anything, just terminates. I'll see if I can find a pic.
Old Dec 27, 2004 | 09:46 AM
dmxsoulja3's Avatar
Default Re: tach lead, cluster or engine bay? (******)
thanks for the help guys...is there a way to get that wire back into the car from out by the firewall easily?
Old Dec 27, 2004 | 09:48 AM
hott95eg's Avatar
You can also use the negative side of the coil for the tach signal too, forget what color wire it is though
Old Dec 27, 2004 | 10:02 AM
suckawillis's Avatar
Default Re: tach lead, cluster or engine bay? (hott95eg)
use the blue wire right by the firewall on the drives side with a black rubber connector on the end of it. dont mess with the coil its internal, if you are stuck using another alternative use the blue wire on the distributor. make it look clean please!
Old Dec 27, 2004 | 10:26 AM
snatch's Avatar
There's no need to bring the wire back inside the car. Run the signal wire from the tach through the firewall and to the blue wire in the engine bay.
Old Dec 27, 2004 | 10:33 AM
BrokeAssWhiteboy's Avatar
my house has wheels on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">There is a blue wire just off the firewall on the driver's side of the engine bay. It's a single blue wire, tap into that. It doesn't even go into anything, just terminates. I'll see if I can find a pic.</TD></TR></TABLE>
yep thats the one to use, its is the rpm signal wire put there by honda for technicians to use
Old Dec 27, 2004 | 10:38 AM
dmxsoulja3's Avatar
Default Re: tach lead, cluster or engine bay? (BrokeAssWhiteboy)
can someone link me to the most complete manual I can purchase, im about to do d15b swap into my daily driver and need something to go by other than haynes or chiltons
Old Dec 27, 2004 | 03:27 PM
what model civic?
Old Dec 28, 2004 | 08:50 AM
dmxsoulja3's Avatar
Default Re: tach lead, cluster or engine bay? (suckawillis)
92-95 coupe
91rexhf
Feb 11, 2009 10:25 AM
tanabe
Oct 14, 2006 02:18 AM
joecivic93
Jan 6, 2004 10:07 PM
xXx Justin xXx
Jun 13, 2002 07:20 PM
CheezeFrog
Jul 19, 2001 07:57 AM
