are all b-series water pump interchangeable?
Old Jan 5, 2002 | 10:23 PM
Eggman's Avatar
Default are all b-series water pump interchangeable?
more specific>
i have a 96 gsr motor with unknown mileage. a friend has a 2000 Si water pump for me if i want it. motor is out so its a simple job. low on cash for a new pump. both look real similar. 22 teeth. any reason i shouldn't do it?
Old Jan 5, 2002 | 10:33 PM
91DA9's Avatar
Default Re: are all b-series water pump interchangeable? (Eggman)
The only thing I can think of that would be different is flow rate, but they are probably the same. Do you or your friend have Helm's manuals?
Old Jan 6, 2002 | 12:11 AM
rainforest's Avatar
Default Re: are all b-series water pump interchangeable? (94IntegraGSR-OVR)
yeah they are all interchageable i have a p30 on my ls/vtec man theer is a huge differeence man it is so much bigger.
Old Jan 6, 2002 | 02:53 AM
sgT's Avatar
sgT
Default Re: are all b-series water pump interchangeable? (rainforest)
The only difference is the size/# of teeth on the gear.
If you use a B18A/B pump on a b18c then you need to use the b18A/B belt.
B16A has to keep the B16A/B17A/B18C pump because the belt will not
fit properly otherwise.
B18A/B/B20 can use the b18c/b16a pump but it has to use the B18C belt.
Old Jan 6, 2002 | 11:09 AM
VaporTrail's Avatar
New User
Default Re: are all b-series water pump interchangeable? (sgT)
you are correct sir!
Old Jan 6, 2002 | 03:46 PM
Giuseppe's Avatar
Default Re: are all b-series water pump interchangeable? (Teken)
can a JDM B16a pump be rebuilt using US replacent parts..???
just curious..??
Old Jan 6, 2002 | 04:24 PM
Jared's Avatar
Default Re: are all b-series water pump interchangeable? (Giuseppe)
Not sure why you'd want to rebuild it. They are very cheap.
Old Jan 7, 2002 | 06:35 AM
VTEC4GS's Avatar
no they are not interchangeable in terms of fitting the belt cover.
greg
Old Jan 7, 2002 | 06:46 AM
WAFFLES's Avatar
Default Re: are all b-series water pump interchangeable? (vtec4gs)
All vtec pumps are the same. I got mine from a 99-00SI for like $50 i think.
Old Jan 13, 2002 | 10:13 PM
b18c1-ek's Avatar
Just picked up a used GSR water pump in good condition... I know it's advised to replace the gasket, but I want to put it in ASAP... can it be reused?
Old Jan 14, 2002 | 12:38 AM
VaporTrail's Avatar
New User
The pump itself is not bigger, just the pulley. The reason it is different than the LS is that the VTEC motors rev higher. With the smaller diameter pulley of the LS, it would spin faster, and possibly cavitate. It would be wise to use a VTEC water pump on any high revving LS.
Old Jan 14, 2002 | 08:02 AM
Eggman's Avatar
Default Re: are all b-series water pump interchangeable? (suprfast)
thanks, thats good to know. glad you posted.
vmolla1
Apr 20, 2014 11:27 PM
mingbling96
Sep 5, 2005 01:19 PM
jdmEFsedan
Mar 3, 2005 11:18 AM
Master23
Jul 7, 2004 10:39 PM
Charlie Moua
Mar 27, 2003 10:47 AM
