New Sleeved block... its rusting!!!!!
ok i have a b16 block that i bought that was sleeved... ive had it in my closet for a couple months, and now it is beginning to rust... what do i need to put on it to make it stop??? it has some sort of oil or grease on it when i got it, but now that is worn off!!!! please help me!!!!
you should take a rag and wipe all the cylinder walls with oil then take and wrap it up in garbage bags to keep it as dry as possible
Just spray some WD-40 on the cylinder walls and the top, clean off the surface rust with a rag, than spray WD-40 again on all parts of the sleeves and you're ready to store that baby for a long time..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr »</TD></TR><TR><TD CLASS="quote">Just spray some WD-40 on the cylinder walls and the top, clean off the surface rust with a rag, than spray WD-40 again on all parts of the sleeves and you're ready to store that baby for a long time..</TD></TR></TABLE>
Exactly. You want the block covered so that the sleeve can stay smooth and moist. remember, the sleeves are of a ductile iron that oxidizes easily.
u sure that wd40 would work? it is a hydrocarbon and i usually dont recommend that to customers, seeing as how i work at a hardware store and i am there now... thanks for the replies!
WD40 is what I used to store mine. It works fine so don't get your panties in a bunch. Just go to walmart, buy a can or two along with a 30 pack of beer.
2 birds with 1 stone killed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe »</TD></TR><TR><TD CLASS="quote">u sure that wd40 would work? it is a hydrocarbon and i usually dont recommend that to customers, seeing as how i work at a hardware store and i am there now... thanks for the replies!
You are right but I have never seen any problems arise from using WD-40 on the cylinder walls. I use Royal Purple assembly lube.
</TD></TR></TABLE>You are right but I have never seen any problems arise from using WD-40 on the cylinder walls. I use Royal Purple assembly lube.
ok so i used some wd40 to clean the rust off, then i soaked the sleeves in oil, wrapped the whole block in a plastic bag, and put it away!!!! that should do it...lol, thanks again for the replies!
