Can spark plug gap cause a "misfire?"
Old Dec 16, 2004 | 12:35 PM
RobbieG35's Avatar
12 Years Strong
Default Can spark plug gap cause a "misfire?"
Every since I boosted my car it has had a misfiring sound at idle. This did not happen when the car was on the motor. I installed a set of new plugs and gapped them at around .030. The car idles like it is misfiring, but drives perfectly while driving normal, and under boost.
I removed the plugs after about 200 miles, cleaned them and regapped them, and the idle was smooth?! Could spark plug gap cause the car to idle like crap?
Old Dec 16, 2004 | 01:21 PM
mrbsponge's Avatar
yes, but it sounds to me like you might be over fueling them at idle, what kind pf fuel management are you running
Old Dec 16, 2004 | 01:34 PM
RobbieG35's Avatar
12 Years Strong
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">yes, but it sounds to me like you might be over fueling them at idle, what kind pf fuel management are you running</TD></TR></TABLE>
Warlbro 255, and a Vortec FMU - Only 7lbs until I can afford a standalone - I had Hondata but sold it when I parted out my last turbo kit
Old Dec 16, 2004 | 03:23 PM
donkiman's Avatar
Default Re: Can spark plug gap cause a "misfire?" (HybridHatch88)
what temperature plug are u running. try gapping them a little closer. how do your ignition wires look? i had some magnecores and they were all beat up so i bought some brand new oem wires and that cured my missfire.
Old Dec 16, 2004 | 05:08 PM
sporkcrx's Avatar
Default Re: Can spark plug gap cause a "misfire?" (donkiman)
You dont need to gap them smaller if it's happening during idle. Are you using stock injectors right now?
dointhemzs
Sep 7, 2008 07:09 PM
thestorysritehur
Mar 11, 2008 08:34 PM
Thanks knightsport!
Apr 9, 2005 02:50 PM
mpociask
12
May 25, 2004 11:22 AM
Br1anPham
Feb 1, 2004 10:15 PM
