chipping p05? vx?
Old Dec 14, 2004 | 04:22 PM
JDM96SpecCTR's Avatar
Default chipping p05? vx?
to use and chip a p05 ecu, do u have to do anything different than a p06 or p28? or is it all the same? what car is that from, the vx? if not will a vx ecu be useable for chipping?
Old Dec 15, 2004 | 06:49 AM
BUMPP
Old Dec 15, 2004 | 10:39 AM
anyone
Old Dec 15, 2004 | 08:49 PM
Big Teggie's Avatar
Default Re: chipping p05? vx? (JDM96SpecCTR)
You can only chip some VX ecu's.
Old Dec 15, 2004 | 11:33 PM
Default Re: chipping p05? vx? (Big Teggie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie &raquo;</TD></TR><TR><TD CLASS="quote">You can only chip some VX ecu's.</TD></TR></TABLE>
okayyyyyy...which ones??
Old Dec 16, 2004 | 04:33 AM
boomslang's Avatar
The VX uses a P07, not P05.
Old Dec 16, 2004 | 04:42 AM
Big Teggie's Avatar
https://honda-tech.com/zerothread?id=1024899
That thread has some info
Old Dec 16, 2004 | 06:16 AM
Honda Bull's Avatar
It's from a 1992-1995 CX I think. I just had a question concerning the P06 just the other day. Because I just got my GSR swap and received the reburnt ECU a few days later. It was supposed to be a P28 done to a P72. But I got a P06 which I had never even heard of.
Old Dec 16, 2004 | 09:32 AM
v4lu3s's Avatar
RTFM
p06 is a non vtec p28, and p05 is a p06 with 1 wire o2 sensor.
Old Dec 23, 2004 | 07:31 AM
Proglow3's Avatar
Default Re: (v4lu3s)
Would it be safe to run the P06 ECM on a d16z6 engine? I know it's the non-vtec ECM with the correct O2 wiring...but that's about all I know about it. I want a P28 but can't afford one right now. What will the effects be, besides no v-tec?
Old Dec 23, 2004 | 11:13 AM
Default Re: (Proglow3)
it should run fine, but like u said no vtec
as long as ur not planning on racing it i dont think u should have any problems
Old Dec 23, 2004 | 11:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">p06 is a non vtec p28, and p05 is a p06 with 1 wire o2 sensor.</TD></TR></TABLE>
so does that mean a p05 cant be used to run a car that doesnt used the 1-wire o2?
Old Dec 23, 2004 | 04:44 PM
Proglow3's Avatar
Default Re: (JDM96SpecCTR)
P05 is from a 92-95 CX civic...that's what I started with. It has one 02 sensor wire and could run your engine, but probably won't run very efficiently. 02 sensors with more wiring have the potential to sense more with it's additional circuitry... Anyways, the additional wires probably will adjust the air/fuel mixture, within your ECM, in a more timely manner. But you said that you have a chipped ECM...so what's it chipped to do?
Old Dec 23, 2004 | 09:59 PM
well i was actually asking about chipping the ecu, i dont have it now...can it be chipped and used to run any car/engine like say a p06 can? it would be used to run uberdata on a turbo d16
Old Dec 25, 2004 | 08:57 AM
b18c1civic95's Avatar
PGMFI.ORG
The Alchemist...
11
Jun 13, 2005 05:43 PM
joepark2001
17
Mar 4, 2004 04:53 AM
oldbeefcake
Aug 22, 2003 11:21 AM
Desperado
Apr 15, 2003 12:51 PM
