How do i get the timing belt drive pulley off?
Old Dec 14, 2004 | 03:38 PM
blackdelslo's Avatar
Default How do i get the timing belt drive pulley off?
Hey im ive almost got the oil pump housing off but the pulley that fits over the crankshaft wont come off to let the housing off. Anyone know how? It doesnt slide off like the balancer shaft pulley did. thanks
Old Dec 14, 2004 | 03:48 PM
@ries's Avatar
Default Re: How do i get the timing belt drive pulley off? (delLudeVTEC)
you need to use a strong impact gun to bust that crank pulley bolt loose.
Old Dec 14, 2004 | 03:53 PM
Default Re: How do i get the timing belt drive pulley off? (@ries)
dude what are you talking about, i almost have the oil pump housing off. meaning all of the timing belt **** is ripped down, the balancer shaft pullies are off but the timing belt pulley that fits over the crank shaft wont come off. the pump housing is trying to come off, its wiggling around but the pulley wont slide off.
jackstands's Avatar
he's talking about the crank sprocket, not the pulley. i don't of any tricks other than pb plaster, and a flathead screwdriver
Old Dec 14, 2004 | 04:01 PM
Default Re: How do i get the timing belt drive pulley off? (jackstands)
i tried a screwdriver and pulling as hard as i could on the pump housing. omg i dont know what to do.
Old Dec 14, 2004 | 04:06 PM
@ries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Hey im ive almost got the oil pump housing off but the pulley that fits over the crankshaft wont come off to let the housing off. Anyone know how? It doesnt slide off like the balancer shaft pulley did. thanks</TD></TR></TABLE>sorry.. i guess i don't read to well.
Old Dec 14, 2004 | 04:39 PM
bump, i really need help here guys, ive pryed on it so hard i bent the screw driver...
Old Dec 14, 2004 | 04:56 PM
$300lude's Avatar
Make sure the shaft isn't boogered up. You may have to get a cheap puller. Advance Auto has them for about $6. The key may be making it tough if it is still in the groove. Just a couple of suggestions.
Old Dec 14, 2004 | 05:06 PM
Default Re: ($300lude)
yeah i looked at some pullers but the teeth need to be really slim because the pulley is really close to the pump housing. would heating up the pulley work?
Old Dec 14, 2004 | 05:23 PM
thehondaguru's Avatar
Default Re: (delLudeVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC &raquo;</TD></TR><TR><TD CLASS="quote">yeah i looked at some pullers but the teeth need to be really slim because the pulley is really close to the pump housing. would heating up the pulley work?</TD></TR></TABLE>
Dont heat that **** up man you will warp it. Get 2 nice sized screwdrivers on either side with a rag on the isde portion of the block so you dont fubar that and work it with some PB blaster or WD-40!
Old Dec 14, 2004 | 05:26 PM
$300lude's Avatar
http://www.partsamerica.com/Pa...=3497
Think you can get one of these pullers behind it?
Old Dec 14, 2004 | 05:33 PM
that puller may work if i grind the teeth down a bit.
You cant stick anything inside the block. oil pump housing doesnt leave any space.
i used wd40 and 2 screw drivers. I think the only thing that is going to work is a puller so i think i will try that tomorrow and ill take a good pic. Thanks
Old Dec 14, 2004 | 09:02 PM
ok, another question, does the key at the end of the crank come out? If so it might be easier for me to remove the pulley. I dont think there is enough room to fit puller teeth behind it.
Old Dec 15, 2004 | 02:02 PM
yes the key comes out. I am telling you you can get something in there. Start with a knife or something
ABCVTEC
Nov 19, 2010 02:20 PM
EG2Driver
Jun 15, 2006 07:24 PM
si_hatch
Dec 20, 2004 04:00 PM
Jorsher
Oct 11, 2004 07:40 PM
Ryan C
Mar 25, 2004 06:30 AM
