replacing timing belt without taking the pulley off?
My crank pulley will not come loose. I dont wanna stick a screwdriver and break it in my tranny. Can i replace my timing belt without takng the pulley off or no?
Re: replacing timing belt without taking the pulley off? (DeadEnd9009)
no. you need to take the pulley off to remove the lower timing belt cover. there's a crank pulley tool on summitracing.com thats made by moroso, just got mine and crank pulley bolt came off like butter.
If is a Manuel, put it in gear and have someone hold the brakes. this method has always worked for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">i get too much flex.....it won't go anywhere</TD></TR></TABLE>
what do you mean you get " too much flex"?
Re: replacing timing belt without taking the pulley off? (hatchedeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchedeg »</TD></TR><TR><TD CLASS="quote">no. you need to take the pulley off to remove the lower timing belt cover. there's a crank pulley tool on summitracing.com thats made by moroso, just got mine and crank pulley bolt came off like butter. </TD></TR></TABLE>
The moroso one only works for some pulleys. If yours doesnt have the socket shaped indention in it(which some sohc dont), the moroso tool wont work.
Re: replacing timing belt without taking the pulley off? (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">The moroso one only works for some pulleys. If yours doesnt have the socket shaped indention in it(which some sohc dont), the moroso tool wont work.</TD></TR></TABLE>
i just ordered on from amazon......can't get my pulley off, it actually made my engine skip a few teeth. Thank god for 1 day shipping
i recently did a timing belt swap also and the pulley is a SOB...we LIGHTLY tapped it with a dead blow hammer and put some WD-40 on it and pulled on it over and over---after a half hour or so it slipped right off--Make sure you don't lose your keyway either--those little buggers are hard to find on a shop floor!
Randysi
12
10-20-2011 03:00 AM
Powered by VTEC
01-29-2008 05:58 PM
