b20 bore
Old Dec 14, 2004 | 01:39 PM
v.i.gsr's Avatar
Default b20 bore
What up people i'm interested in doing a b20vtec. I would be sleeving the block,so I would like to know whats the largest bore I can have on this setup.
Old Dec 14, 2004 | 02:25 PM
v4lu3s's Avatar
RTFM
contact the supplier of the sleeves you will use as it varies based on their specs on teh sleeves
Old Dec 14, 2004 | 02:33 PM
Spade's Avatar
Default Re: b20 bore (v.i.gsr)
I believe the largest most people go with a B series is 87mm. That's really pushing it though.
Why would you bother building a "B20VTEC" if you're going to sleeve and bore the block anyway?
The stroke is the same as a LS block and, you loose out on oil coolers and girdle if you don't use the GSR block.
If you have the VTEC bottom block, I'd stick with that.
B20 bottom ends are typically used for people who don't have the money to have a block sleeved but want the larger displacement.
Old Dec 16, 2004 | 05:42 AM
mugencivic4dr's Avatar
Default Re: b20 bore (Spade)
i heard that b20/v is not as reliable as ls/v...
Old Dec 16, 2004 | 05:53 AM
thid92's Avatar
can I haz?
I got mine sleeved to 85 but i am going for boost but like it was mentioned earlier 87 is the largest if going NA
Old Dec 16, 2004 | 12:35 PM
X-Mazda 3 Racer's Avatar
Default Re: (thid92)
87 is the max for all-motor race only application, but 85 is the max for turbo. May want to stay just shy of the max size so you have some room to re-bore if needed!
Old Dec 16, 2004 | 12:59 PM
beerbongskickass's Avatar
Default Re: (GoldenEagleMfg.com)
All aftermarket b-series sleeves start out at 81mm anyways, but like these other guys said you can have it bored a bit bigger for some applications. I would leave some room for a rebuild though just to be safe. Just get yourself an LS block because the b20 block will cost a little bit more to sleeve because of the funky stock sleeve desgin (different than other b-series motors).
Old Dec 16, 2004 | 01:04 PM
Default Re: (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">All aftermarket b-series sleeves start out at 81mm anyways, but like these other guys said you can have it bored a bit bigger for some applications. I would leave some room for a rebuild though just to be safe. Just get yourself an LS block because the b20 block will cost a little bit more to sleeve because of the funky stock sleeve desgin (different than other b-series motors).</TD></TR></TABLE>
Exactly!
Old Dec 16, 2004 | 01:06 PM
Fate's Avatar
golden eagle has some nice sleeves and they are not that expensive. I don't understand why people dis on the b20 so much. it puts out so much more TQ than any other B-Series motor. I would only take a B20 out to 2.1 or 2.2(race only application). But get it built buy a race shop for something 2.2L. its gona take alot to make a B20 that size and keep it running strong.
Old Dec 16, 2004 | 01:15 PM
Default Re: (EGRacersInc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRacersInc &raquo;</TD></TR><TR><TD CLASS="quote">golden eagle has some nice sleeves and they are not that expensive. </TD></TR></TABLE>
Thanks
lakai_19
May 21, 2007 02:25 PM
JDM KID 510
10
Jan 29, 2006 06:14 AM
hoskos
Dec 12, 2005 08:08 PM
Boostless97Lude
Nov 20, 2002 07:19 PM
TypeR0149
Aug 22, 2001 12:32 AM
