why isnt my vtec working?
Old Dec 12, 2004 | 09:29 PM
b16a_boy's Avatar
Default why isnt my vtec working?
I own a 1989 honda integra xsi vtec. Recently my engine check light came on and since then vtec has not been working. My mechanic cannot figure out what is wrong, he has checked both my distributor and computer: both seeming to be fine. Any ideas on what is wrong with my teg?
Old Dec 12, 2004 | 09:41 PM
PREwryann's Avatar
Default Re: why isnt my vtec working? (b16_boy)
check wiring frist, mybe put batt. plus to vtec spoll valve. start there just work your way throgh is dont forget the small easy things (does motor have oil) good luck!
Old Dec 12, 2004 | 09:46 PM
mmuller's Avatar
Mad Scientist
Default Re: why isnt my vtec working? (PREwryann)
whats the code that the check engine light is giving you?
Old Dec 12, 2004 | 09:54 PM
b16a_boy's Avatar
Default Re: why isnt my vtec working? (mmuller)
When the mechanic ran the check on the light it came back with codes for ignition and the cam angle sensor. Im starting to think that the problem lies with wiring.
Old Dec 12, 2004 | 09:55 PM
mmuller's Avatar
Mad Scientist
check your dizzy
Old Dec 12, 2004 | 10:01 PM
b16a_boy's Avatar
Thats the thing, my mechanic sent my dizzy away for checking and it checked out all good. He even tested a new dizzy in my car and the prob was still there.
Old Dec 12, 2004 | 10:10 PM
mmuller's Avatar
Mad Scientist
well, cam angle sensor is inside the dizzy so..
and you sayd code for ignition module? icm
thas inside the dizzy too
edit: have you messed with the wiring?
Modified by mmuller at 2:26 AM 12/13/2004
EGThang
18
Jun 6, 2008 03:26 PM
TheIceMan
Dec 10, 2005 11:33 AM
proracer718
Sep 3, 2005 09:23 AM
veilsides2000
Nov 27, 2004 11:18 PM
patdemps
May 27, 2004 11:32 AM
