What ecu to use with b20/vtec swap?
Old Dec 6, 2004 | 07:36 AM
weraider30's Avatar
Default What ecu to use with b20/vtec swap?
doing a b20b block/b16a2 head swap, what ecu to use with b16 harness?
Old Dec 6, 2004 | 07:56 AM
drdisco69's Avatar
Default Re: What ecu to use with b20/vtec swap? (weraider30)
OBD0, OBD1 or OBD2...?
Old Dec 6, 2004 | 08:12 AM
weraider30's Avatar
Default Re: What ecu to use with b20/vtec swap? (drdisco69)
obd1
Old Dec 6, 2004 | 11:51 AM
weraider30's Avatar
ttt
Old Dec 15, 2004 | 08:44 PM
drewbie*'s Avatar
would like to know as well
Old Dec 15, 2004 | 09:17 PM
kinvid22's Avatar
Default Re: What ecu to use with b20/vtec swap? (Drew95eg)
i got the same set up...using a chipped p28 (92-95 civic ex) ecu...custom program from a fellow honda-tech member...
you can use a 98-00 type r ecu if going obd2, otherwise chipped p28 (obd1)
Old Dec 16, 2004 | 06:07 AM
weraider30's Avatar
Default Re: What ecu to use with b20/vtec swap? (kinvid)
i ended up buying obd2 harness, dizzy, and ecu from a 00 si, thanks
Old Dec 16, 2004 | 11:58 PM
kinvid22's Avatar
you're converting from a obd1 car to obd2b?...good luck...hope you have a obd1--->obd2b conversion harness, some obd2 sensors like crank fluctuation, and a secondary o2 sensor
Old Dec 17, 2004 | 02:55 AM
smart monkey's Avatar
if it were me and the car is OBD1 I would go hondata on a P28 and create a tune for that motor since CRVTECS don't exist from honda directly
Old Dec 17, 2004 | 08:47 AM
weraider30's Avatar
Default Re: What ecu to use with b20/vtec swap? (smart monkey)
will i need a conversion harness if i bought an obd2b wiring harness and ecu?
Old Dec 17, 2004 | 08:52 AM
mmuller's Avatar
Mad Scientist
you gonna need more fuel and different timing than what the 99si ecu is going to give you .
seriously, stay obd1
Old Dec 17, 2004 | 08:57 AM
kinvid22's Avatar
oh sorry no you don't need a conversion harness since the obd2b engine harness will plug directly into your obd2b si ecu. However you might want to check up on the extra obd2 sensors that your SI ecu will be picking up. if your motor is obd2 and has all those sensors, you should be fine. oh yes, you want no cel with o2 sensors? then add the secondary one after the cat or so.
stay obd1 but want to use the SI engine harness? get a obd2b--->obd1 conv harness...
Old Dec 17, 2004 | 09:12 AM
SCYRIO's Avatar
YEP, B20 V-TEC (GSR HEAD) IS THE WAY TO GO
OBD-1 WITH A P28 (92-95 CIVIC) ECU NO NOCK SENSOR. CHIPPED AND TUNNED, ALSO IT WOULD BE GOOD TO GET SOME NEW FUEL INJECTORS TO RUN BETTER...310 CC OR HIGHER
Old Dec 17, 2004 | 09:35 AM
weraider30's Avatar
Default Re: What ecu to use with b20/vtec swap? (SCYRIO)
there is no point in staying obd1 if i already had all the obd2 stuff
Old Dec 17, 2004 | 09:45 AM
SCYRIO's Avatar
cool, cool, good point.... you'll love this engine. I do !!!!
Ef7-crx
Dec 18, 2018 09:39 AM
vlc92189
10
Jan 29, 2010 10:50 AM
Wonk Unit
Feb 11, 2007 10:26 AM
spool310
Sep 6, 2006 10:02 AM
Nikos
Jul 3, 2003 08:22 AM
