B17A bored and sleeved to 84.5mmm good for FI?????
Old Jan 1, 2002 | 02:15 PM
1's Avatar
Default B17A bored and sleeved to 84.5mmm good for FI?????
I am going to use JE pistons(9.5:1), Crower rods, and iron sleeves with my stock B17A crank. This should yield about 1.9L (?). Anyone see why this bottom end shouldn't be able to produce
350 w.h.p. at high boost?
TIA
Old Jan 1, 2002 | 03:48 PM
Ray's Avatar
Ray
New User
Default Re: B17A bored and sleeved to 84.5mmm good for FI????? (1)
b17 crank with a b17 or b20 block?
Old Jan 1, 2002 | 03:56 PM
1's Avatar
Default Re: B17A bored and sleeved to 84.5mmm good for FI????? (Ray)
B17 of course...
Old Jan 1, 2002 | 04:02 PM
Ray's Avatar
Ray
New User
so with good right tuning and enough boost yes you can reach 350hp, no exact #s since every setup varies.
Old Jan 1, 2002 | 04:14 PM
1's Avatar
Do you see any problems with this setup? I might have to modify my JE pistons from my B20 setup to work in the shorter deck B20
Old Jan 1, 2002 | 07:42 PM
88CRXHybrid's Avatar
it will displace 1.826L. What rod length are you going to use?
Old Jan 1, 2002 | 07:56 PM
1's Avatar
Default Re: B17A bored and sleeved to 84.5mmm good for FI????? (88CRXHybrid)
This is one of the factors I have yet to figure out. What do you suggest?
Old Jan 2, 2002 | 06:12 AM
SpeedMonkeyRacing's Avatar
84.5mm? damn....i'm doing 83.5 on my b18c1 block...i dunno if that's an good idea for b17 block or not. Be careful
Jeff-
Old Jan 2, 2002 | 09:35 AM
VTEC4GS's Avatar
its sounds like a nice setup, honestly but you're changing the b17 significantly by having a bigger bore than the stock stroke which can have repurcussions.
Greg
Old Jan 2, 2002 | 04:07 PM
1's Avatar
Default Re: B17A bored and sleeved to 84.5mmm good for FI????? (vtec4gs)
Does anyone know details of why I shouldn't have the setup this way?
Old Jan 2, 2002 | 08:26 PM
get it resleeved to 84.5mm by golden eagle and you should be fine. I dont know the stock deck height of the B17A nor the stock compression height, distance from center of wrist pin to top of piston deck(not including the dome of course), of the pistons you are going to try to use. You will have to know those two numbers and stroke(81.4mm) to find what rod length you should use. Do some research and find those numbers. Then I can help further.
Old Jan 2, 2002 | 10:23 PM
just_a_sohc's Avatar
you might have a 84 mm B17 block with super-double-wack sleeves but it’s not the equivalent of a B20b/z block with its thicker walls and the same sleeves.
dannyneedshelp
Oct 15, 2008 09:22 PM
drSquish
Mar 17, 2008 05:17 AM
freakin
May 1, 2006 02:38 PM
Mentat Ghola
10
Apr 16, 2004 06:07 AM
Dec 20, 2001 07:22 PM
