OBD1 to OBD2
Old Dec 30, 2001 | 11:11 PM
Patron's Avatar
Default OBD1 to OBD2
how difficult would it be to switch obdI to obdII. what would i need to do to drop a '98 ls motor into a '95 civic? thanks
Old Dec 31, 2001 | 06:40 AM
Spade's Avatar
Default Re: OBD1 to OBD2 (ptran13)
DON"T DO IT!!! OBDII is not programable. Swap the OBDI parts onto the LS engine and smog it as a OBDI engine.....not sure what year but that is all ya have to do man.
Oh and to answer you question......you need everything that comes with a "complete swap" for the LS, all sensors, distributor and injectors, anything that is going to be controlled by the ECU. But IMO, if you don't HAVE to convert to OBDII, don't!
[Modified by Spade, 8:51 AM 12/31/2001]
Old Dec 31, 2001 | 08:56 PM
Kataku2K3's Avatar
You don't even have to do that if you have a 95 civic the 98 ls motor will plug straight in if you have the harness or you can rework ur civic harness, but if you do so you will need to cut the plug off of ur civic distributor and put it on the LS so that the integra distributor will plug into the civic harness. On the newer motors there is a secondary O2 sensor and a crank speed fluctuation sensor and a couple others. You will need an OBD1 ls ecu and when you plug ur new motor in the computer won't even look for those several sensors. Have fun!
[Modified by JDMspecEG6, 8:49 AM 1/1/2002]
eM1_kiD
Aug 1, 2013 12:00 PM
carma42
Jan 17, 2006 05:37 AM
greddydc5
Jun 14, 2005 10:45 AM
Patron
Jan 2, 2002 02:43 PM
Patron
Jan 2, 2002 05:51 AM
